This is more than likely an issue with the monitors themselves. Does this happen on the main monitor is you move the secondary cable over to it? What kind of monitors are you using, how old are they, and do you know the refresh rates on them?
Are you using a Nvidia gfx card? If so, then go into the setup menu (comes with all Nvidia drivers). in the "screen size" menu, there should be a list of the supported screen resolutions. Do remember that the cable you use (HDMI, Display Port, VGA, DVI etc. ), also has an effect on the screen resolution.
If your screen has a VGA, DVI, or HDMI port, most of the new graphics cards will be compatible with your screen. Most graphics cards come standard with DVI ports and include a vga adapter for the screen cable. Some of the new graphics cards come with HDMI and DVI ports or a HDMI converter if you want to use HDMI.
I would recommend a Nvidia graphics card. Depending on what your primary use is going to be they have an extensive range to cater for your requirements and price range.
you can not use both the on board and external pci-e card. only the pci-e card however you can still use duel monitors by getting a dvi to vga adapter and running the nvidia configuration utility.
Hi, What you have to do is shut down the machine, pull the CMOS battery(CR2032) out and out and put your jumper on pins 1-2 from 2-3. Wait 30 seconds and put the battery back in. After installing the battery, put your jumper back to pins 2-3 from 1-2. This should work.
