Question about Hobby Zone Hobbyzone Super Cub Propeller Rc Airplane
Elevator on tail will not move after accident
How do i get the tail section operating again so i can fly? ty
    Sergeant:
  • 352 Answers
EITHER YOUR ELEVATOR CONTROL CABLE IS BENT OR MISSING, OR THE ELEVATOR ACTUATOR SERVO IS NOT FUNCTIONING
NOTE:**** CHECK ALL OPERATIONS BEFORE TAKING TO THE AIR AGAIN...IT GETS COSTLY!!!
Posted on Jul 21, 2013
Tail rotor blade is bent and helicopter wont fly forward or backwards
Fixing Your RC Helicopter - The Basics + Tips / Tricks ...
? 3:26
https://www.youtube.com/watch?v=Gxst73zE0VY
Jan 16, 2011 - Uploaded by Live2Fly94
i have a heli and the tail rotor will spin right but not left .... im having problems with my silverlit nano copter the tail ...
Frequently Asked Questions - RC Helicopter Wiki
www.rcheliwiki.com/Frequently_Asked_Questions
Probably the best way to learn to fly is to find a group of like minded people locally and ask their advice. ... The tail rotor should rotate so that the blades come 'up' towards the front of the heli. ... My helicopter won't stop spinning! ... still flying awesome but now tail vibrate and it issues backward forward. what should i do ?
Dec 28, 2015 | Toys
How do I shorten up a 40' hay elevator ? Is there sections I can take out or do I torch ?
If you take a section out, you then have to deal with the Belt. Why not lower the Elevator or move to an angle?
Oct 02, 2014 | Cars & Trucks
Pro runner 1600 treadmill
this is a error with two alternatives; God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Oct 24, 2013 | Tunturi Exercise & Fitness
Endurance xt3300
follow the steps and fix it. God bless you. You have 2 alternatives with this error.
2)Alternative:
Jun 19, 2013 | Exercise & Fitness
Error code e7 on trojen staminia 310 - already tried switching off and on again. I washed machine and mistakenly got the motor wet.
see the next steps. God bless you
ERROR CODE # 7
2)Alternative:
Nov 16, 2012 | Exercise & Fitness
My 9053 lifts off fine goes left right and reverse. but it goes reverse also when i want to go forward . Tail rotor turns at what appears proper rpm. and it changes direction when i push stick from reverse...
I own this heli also. The problem is that the tail rotor does not apply enough push to tilt the heli forward. It is this forward pitch that moves the heli forward. Aside form buying a stronger tail motor, upgrading your battery etc, the only thing you can do id this:
Get a credit card, a pair of scissors and some tape. Cut a couple of strips from the credit card about 2 1/2 - 3 times wider thhan the tail rotor blades and the same length. Now tape the strips to the top of the tail rotor blades. Make sure you don't increase the length.
This will help a little by providing more air push when the tail rotor in engaged. Without some serious modding, this heli will never be great.
I have more fun flying my micro size syma helicopter in the garage then I have flying my volitation. If there is even the slightest breeze, the volitation will float in the direction of the breeze and will not fly against it.
Apr 03, 2011 | xheli 9053 Outdoor Volitation Metal...
Wen i put the batteries on the control and followd the instructions the light keeps flashing and it wont work to fly my helicopter uj377
I may need more details but is this the way it goes?
1. Turn on the radio, or remote control
2. Turn the power switch in the copter to the on position
At this point, you should see the green light flashing on the control. Simply move the lever that controls your elevation to the full up position and then let it come back down to neutral. The light on your control should now be on with no blinking.
At this point, you are ready to go as advancing that "up" lever again will get that rotor spinning!
The manufacture set it up this way so that you dont accidently "bump" the control before you are actually ready to fly which prevents injury or damage to the copter.
Jan 12, 2011 | Toys
Brand new unit forward and reverse seems very slow moves a little then just hovers.
Make sure you're charging fully, until the light on the charger doesn't get ANY brighter when you unplug the helicopter. Also, battery must be allowed to cool 10 minutes after flying AND another 10 minutes after charging.
Most crucial is that you must never fully discharge battery. Fully draining a Li/Po even once (especially when it's new) can cripple or ruin your battery. As soon as you are unable to maintain altitude, land copter and power it off. Also, there is a button on the remote, labelled "tail motor speed switch" located near the trim control. With it in the "off" or up position the tail motor is much slower allowing for more precise control. When button is pushed to the down or "on" position, tail motor moves faster giving more tilt, and thereby much more forward/reverse 'thrust'. Verify that tail rotor is moving when right joystick is actuated (and that it reverses when right stick is pulled in opposite direction) and that it isn't loose on it's shaft... this can be tested by verifying tail rotor spin in one direction then reversing joystick... tail rotor should instantly start spinning in the other direction with NO hesitation, if it slows and then starts spinning in other direction or anything like that then it's loose. Turn helicopter upside down then VERY CAREFULLY apply a small drop of super glue where the shaft meets the tail rotor, be very cautious to not get any glue near where the shaft comes out of the motor, and do not turn right side up until glue is fully dry.
Hope this helps,
r
Jan 07, 2011 | SYMA Toys industrial Syma S032 Ready to...
Hobby Zone Hobbyzone Super Cub Propeller Rc Airplane Logo
91 people viewed this question
Top Hobby Zone Toys Experts
MeAndMyBrain
Level 1 Expert
ZTW Official
ZTW Official
Level 1 Expert
Are you a Hobby Zone Toy Expert? Answer questions, earn points and help others
