Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Jammed, what kind of allen tool should I use?
  • Ace Hardware Master
  • 5,245 Answers
Just use broomstick. Otherwise allan wrench I think 1/4" size fit into slot on bottom. Buy several sizes and check which works.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#stuck
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jul 20, 2013
How do you fix a stuck firing pin on a dealt siding nailer
Not sure what model of gun you have. If it is a dcn690/692 undo the 2 allen screws above th nose and the allen screw near the battery. The magazine will then come away and you can clear the jam. Note there may be paper bunched up under the nose or the top of the magazine, this is the paper collation off of the nail strips tis could help cause a jam.
Dec 03, 2017 | Air Tools & Compressors
Ihave a nail jammed in my gun,I believe there is a release gate but how to open it?
Is this a Dewalt gun?There is a faceplate in front of the barrel/slot. That's what you want to remove. Find the appropriate allen wrench and remove the bolts Your "jam" will be mostly exposed. 9 times out of 10 it's two nails that are wedged together or a bent nail. Using thin sharp tool or another nail pry the jammed nail(s) out. Note: be sure to keep that slot oiled, it is very important!
Jun 02, 2015 | Tools & Hardware - Others
DISPOSAL DOES NOT WORK.
There is something caught in bottom of it!to clear it you need a Allen wrench on the bottom of disposal.
Jan 25, 2015 | Electrical Supplies
Arrow ct50
Why not take the stapler with you to a hardware store or any other place where they sell tools (like Sears, Home Depot, or Lowe's) and try matching up the size of the screw to the Allen wrenches they have on display?- it may be a metric or SAE size. Are you sure it's not a Torx screw?
If all else fails, call the Arrow company's support line and ask them. Just remember to remove the battery pack whenever you are doing any type of servicing to it and wear safety glasses or goggles.
Nov 30, 2013 | Tools & Hardware - Others
TNT XAGD50 brad nailer is jammed
If the jam is bad enough you may just have to pull the 3 front magazine screws (metric allen screws) and the one in the rear that holds the magazine to the tool frame. That way you can pull the entire magazine off which will expose the nose area and you can remove the jammed nail.
Jul 28, 2012 | Sears TNT 3 gal Air Compressor with 2 in...
What kind of tool do I need to remove the distributror cap,screwdriver or allen wrench or what? vehicle is a 1999 chevy silverado 4.3 V-6
Those older GM distributor caps can require a 1/4" socket, 7mm socket, Phillips head screwdriver. Look at it and match the tool to the fastener.
Sep 10, 2011 | 1999 Chevrolet Silverado 1500
Once the disposal is running again (it was jammed, and I turned the allen weench back and forth) is there anything else that I need to do or tighten? thank you
It depends on what jammed it in the first place. If you flushed everything out then you're fine. With the electric off, look inside with a flashlight and be sure there isn't any foreign object left in the disposal. Metal or glass will jam again, and could be merely lodged against the side now. Use tongs or other tool not your hand to remove anything left behind.
Nov 28, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Trying to disassemble Ladylux Cafe faucet. Grohe
If it is just replacing the handle you will only need a smaller screwdriver set (pretty common) and an allen wrench. I don't know exactly what size you need but you can get a set of these wrenches pretty cheap at any tool or hardware store. Basically the tool is a hexagonal rod that is bent in the shape of an "L". You'll need the smaller set for this job sold usually in sets that have a range of sizes from .05" to 3/8" diameter. I would guess your hex nut is 1/8" or less.
On the bottom of the handle between the sink bed and the handle you'll be able to feel a small hole. When you stick the allen wrench in there it should fit snuggly if the allen wrench wiggles a lot go to the next size up. Since the screw is facing up you will pull the other end of the wrench toward you. This will loosen the screw. It will not take a lot of effort so if you have to force it make sure the allen wrench is actually seated. Kind of a pain but you'll have to reposition the wrench as you get it loosened to fully extract the screw.
Once the screw is out the handle will drop down and the cap just pulls off. Assembly is reverse but make sure that your screw is going into the threads without resistance before tightening. This will prevent cross threading.
Feb 15, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
No power
Something probably jammed the disposer and tripped the overload. Look on the bottom of the disposer for a red reset button and push it in. Try to run the disposer. If it trips again, there is probably something jamming it.
Make sure the switch is OFF, then try to find the allen wrench that came with the unit and insert it in the hex hole in the bottom center of the disposer and turn it back and forth until it breaks free what ever was jamming it.
If you can't find the allen wrench that came with the unit, if I remember correctly, it's a 1/4" allen wrench, available at most any place that sells tools.
If you still have no power, go the your main circuit breaker panel and look for a breaker that has tripped. Turn it OFF then back ON.
It's possible the switch is bad but not likely. It's possible the motor is bad, but again, not as likely as just being jammed or just needs reset.
Jan 01, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
89 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
