Question about Neff Ovens
Neff oven C43 error
Hi. We've just installed a new NEFF B45C52N3GB oven and have the fault code C43 on the display. We don't have a manual for the oven, and am struggling to find one online. Anyone know where we could get some information to solve this problem please?
4 Suggested Answers
  • 1462 Answers
SOURCE: neff oven won't work after a power cut
you need to reset clock - get your book out and it gives instructions
Posted on Oct 08, 2008
SOURCE: neff oven U1661 shows fault code -5-
We have a similar Neff Oven - it is a child proof lock that you have activated. To deactivate - turn the left hand dial that selects the mode of cooking - three times to the left and back (turn it from 12 oclock to 11 oclock and back) in quick succession.
Posted on Nov 01, 2008
SOURCE: Neff oven B1641
Turn the right hand button onto the ECS symbol. This is the cleaning cycle. Make sure you put some soapy water in the 'well' at the bottom of the oven. The oven is then steam cleaned.
Posted on Mar 08, 2009
Any idea what error code EO533 on a Neff single oven indicates
https://www.northlondonappliancerepairs.co.uk/error-codes/neff-error-codes.html
Nov 19, 2017 | Neff Ovens
Where can I get installation and operating instructions for a NEFF 29c warming drawer?
Hi Pat,
I suggest contacting Neff directly. You can email them or telehone them from choices on the page linked below:
http://www.neff.co.uk/customer-service.html
Apr 14, 2015 | Neff Ovens
Neff oven dial symbols
Try Googling (Neff)(model)(manual) without parens for information. You may have two different models.
Jan 20, 2018 | Ovens
Oven temperature on Neff 195305317 circotherm oven
hi remember that electric can kill you even if it is unplugged, if you don't know what components are likely to hold charge or have large inductance get someone else to fix it.
you need to get the service manual as tis will have fault finding charts, part numbers, location of sensors etc. If you can't get manual then:
Not likely to be temp limiter as this cuts out if temp is too hot. Find temp probe, may be ntc, mercury vapour switch etc. take probe out disconnect leads and measure resistance, heat, or cool, probe measure resistance if not significantly different (ie 10k to 100k or 100k to 300k) then probe is shot. Take probe to spares place, get replacement and refit. Be very careful to refit leads exactly as they came out, don't want insulation to melt and oven to become live. test with oven or meat thermometer as new sensor may need calibration. Should be accurate to within 10C or so
hope this helps
Nov 10, 2012 | Neff Ovens
Neff B4562
Engineer is a solution.
The other solution is;
Switch 3 times between rotisserie and pyrolysis or bread baking setting and pyrolysis.
As acknowledgement the displays are actuated.
At each change of operating modes switch immediately stops the current test step and the next step of the test enabled. The oven light should according to the mode ON or OFF; that is, at pyrolysis OFF otherwise ON.
Jul 01, 2012 | Ovens
Shelf fitting slot broken off
Use the link http://www.neff-eshop.com/eshop/neff/gb/prodlg.htm?x=0&y=0&Maktx=Neff+U1721&eshoptype=Aenter the FULL enr from the rating plate, don't just pick the nearest one if the enr is U1721N0GB/75 that's the model you need to check as parts from one model to another can vary. This will open a diagramatic breakdown of the oven and you can search for the relevant part (and buy if online direct from Neff). Couple of things to remember, make sure you have the right oven (ie top or bottom) and whether it is the front or rear holder as one is like a keyhole and the other is a keyhole on its side.As this is a build under unit, it does make changing the part a little easier (depending on which one is broken, hoping for your sake that it's not the back top oven one..Argggh!!) You will need to get the oven out and I find it easier if it's on it's side with the faulty holder at the top. The side panel needs to come off (or at least be loose if it's a front holder) as the holders are held in place by a retaining clip behind the cavity wall, or if it is a screw in type, the screws comes in from behind the cavity wall. I suggest you order and get the parts first and this will give you an idea what you're dealing with. Let me know how you go and post any comments or problems you have whilst doing the repair (anything I've forgot to add) as this will help anyone else looking for a solution to a similar problem.Ps. If you are sensitive to fibreglass, wear a pair of gloves.
Nov 23, 2011 | Neff U1721 Double circotherm Electric Oven
Hi got a NEFF B1691 oven. Thing is the oven light, element and fan keep switching off during cooking is this correct functionality - if not what could be wrong? The temperature display remains functioning...
There does seem to be a fault, as the fan should run continuously even when the element goes off at the required temperature setting, and the light should atay on as well.
It suggests to me that there is a fault with the oven thermostat, or it is wired incorrectly.
Dec 21, 2010 | Neff B1691 Single circotherm super...
Er 07
i can't help you with this brand but in almost all oven of this type . inside behind the display board is a tech sheet. it will have all the answer's fault codes are a common way for self diag ovens and other appliances .. mm
Jul 14, 2010 | Neff B1421 Electric Single Oven
The fan system does not heat up the oven
Hi.
If the fan is working o/k, then you need to fit a new oven element. Very common fault on Neff oven's.
Please rate my solutrion.
Thanks.
Jul 19, 2009 | Neff Ovens
Fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Dec 19, 2008 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
96 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
