Question about Rinnai Water Heaters
How do you fix rinnai tankless water heater code 79
I understand code 79 is an internal water leak. We had a major rainstorm yesterday, so I'm guessing water got into the air vent. This is a brand new house, so there's little chance it's anything else. What's the fix for this? Do I need to just let it dry out, or am I going to need to spend $500 for a plumber to come out on the weekend to fix it?
  • 7 more comments
  • Barry Zatkalik
    Barry Zatkalik Dec 07, 2013
    Hey bulldog what was the final outcome of your error code 79
  • gary
    gary Jun 27, 2014
    How to fix Code 79. Open up the
  • gary
    gary Jun 27, 2014
    Code 79..(leak sensor detected leak). Open up the cover of the unit by
  • gary
    gary Jun 27, 2014
    Sorry..stupid typing..Ok here we go now...Code 79 fix..First and most important. UNPLUG THE POWER CORD. Open up the unit by removing the 2 gray trim strips. 1 on each side(they pop right off). Remove the 4 phillips head screws holding the cover on. Look toward the bottom of the unit. You will see a small white plastic surface mounted piece with a white wire coming off of it. Thats the leak sensor. When activated it will present a code 79 and shut the unit down not allowing any water to flow through it or flame to ignite. If there is water present around it then find out what caused the water? Was it just a big rain storm? Condensate present? Or do you actually have a leak in the tank somehwere. Most likely it was caused by condensation and/or rain. If thats the case your in luck. Take a small compressor and blow/dry the water off. Plug the unit back in and run some water on the hot side of a faucet. It should be fixed now. Replace your cover and your done. If there was no water present then most likely you have a bad leak sensor. No problem...Theres a quick fix until you can get a new leak sensor and replace it. Follow the white wire coming from the sensor. You will see a disconnect (wire harness) half way up the wire. Unclip it so your now breaking that electrical circuit. That bypasses the switch and tells the unit everything is fine. After unclipping it, plug the unit back in. Run water on the hot side of a fixture and it should fire right up. Replace your cover and order a new leak sensor. Replacing it is simiple as you can see it's only held in by 1 screw..Hope this helps ya.
  • Bulldog9816 Jun 29, 2014
    Unplugged the unit and let it dry out for a couple of days to let the water around the leak sensor evaporate, then restart. It's worked like a charm ever since.
    Unplugged the unit for a couple of days of cold showers, and let the lead sensor dry out. It's worked like a charm ever since.
    Unplugged the unit for a couplke of days (cold showers during that time!), and let the leak sensor dry out. It's worked like a charm ever since.
  • Anonymous May 02, 2017
    Take front cover off in bottom right there will be a little water use toilet paper or straw remove water plug in and use. reason water got in mine sidewase rain came in vent pipe. option 2 drill little hole to let water out.
  • Jay Ward
    Jay Ward Jul 15, 2017
    Gary, you are the MAN!! Just unplugged the sensor & my water heater is working again!! Thanks!!!
  • Rinnai Master
  • 5,245 Answers
Do not spend 500 on plumber to determine that condensate drain was not installed properly on vent line, and that acidic water from combustion by-product has been dripping down into tankless and burning hole through the special-alloy heat exchanger instead of going down into floor drain and corroding your plumbing pipes.
Do not spend hours fulfilling the required monthly and yearly maintenance, or spend money on service call each year to get the burner cleaned and gas pressure checked on your tankless computer that heats water...
Instead, fix any tankless problem, any brand tankless, same day do-it-yourself for $385, by replacing 1 part: the whole thing:http://waterheatertimer.org/How-to-install-gas-water-heater.html
Do not install tankless.
Gene
Posted on Jul 21, 2013
  • 244 Answers
SOURCE: Paloma tankless, gas, water heater, error code C7 76
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
Posted on Nov 01, 2009
  • 6 Answers
SOURCE: vinegar flush
You should not have to flush unless the code LC comes up. but here is the flushing diagram.
Posted on Aug 01, 2009
cballard
  • 18 Answers
SOURCE: Rinnai tankless water heater code 12
12 - Flame Failure or Poor Ground
1. Immediate code 12 is usually a defective gas valve, power supply problem, or defective fan motor wiring harness.
2. If code 12 occurs after a few seconds it indicates that proper operation was established, but then stopped unexpectedly.
3. Verify that fuel is being supplied to the unit.
4. Check for proper electrical ground. Unit must use a grounded power supply.
5. Check for flue blockage on inlet or exhaust.
http://www.foreverhotwater.com/service-codes.php
Posted on Dec 31, 2008
  • 48 Answers
SOURCE: Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Posted on Jan 16, 2010
  • 494 Answers
SOURCE: Rheem Power Vent 2 water heater is flashing 4
The flashing light is a trouble sequence light. Find your manual to see what 4 flashes means. It's usually attached to the side of the water heater tank. Try a quick fix by unplugging the power vent and see what happens.
Posted on May 15, 2010
My Rinnai tankless water heater flashes 11 when calling for hot water.
Your Owner's manual should help. No manual, try MFG website, or email their customer service. Or try manualslib.com
Apr 27, 2015 | Rinnai Water Heaters
Rinnai tankless hot water heater
Try replacement valve or solinoid for it on Ebay, or MFG website, or their customer service web site. They may not help due to critical safety issues with DIY fixes.
Apr 14, 2015 | Rinnai R94lsi Tankless Water Heater-...
Where is the leak sensor located?
Rinnai V65iN Installation Instructions and Product Brochures . Please school to the bottom of this link. You find a directory which includes technical manuals and support. Provide the information. And someone will get right to you. You probably fixed it by now. Here is your sourcing.
Apr 28, 2014 | Rinnai V65i-N Internal Natural Gas...
I have a Rinnai Tankless Water Heater with a recurring failure to start problem (Code 11)
The first thing that you should do is get a water sample and have it tested for TUBIDITY. Then see what the contaminates are. This will tell you what the problem is. I seriously doubt what Rinnai is telling you is the truth. Then you need to look into a whole house water filter that has an NSF recommendation. That will stop all the issues that you are having.
Dec 02, 2013 | Rinnai Water Heaters
Keep getting error code 10 for our rinnai rl75 tankless water heater how can we fix this?>
Go to the manual or go on line for the manual and look up the code and its meaning.
Aug 14, 2013 | Rinnai Tankless Water Heater Internal...
Controller not working
The rinnai is a computer that heats water. It is not ordinary water heater most people are familiar with, and repairs are not do-it-yourself, requiring a trained technician qualified in that brand who can diagnose both computer and water heater problems and plumbing problems.
Call rinnai for recommended local technician. Click on support tab. Note their webpage is very short on repair details, unlike companies that sell tank-type heaters... because tankless units are not do-it-yourself.
http://www.rinnai.us/tankless-water-heater
Problem might be simple blown glass fuse on circuit board or complete failure of computer and sensors.
Here is page written for Rheem tankless, that explains general complexity of tankless computers, and showing required maintenance, such as deliming each year:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
To save problems with tankless computers plus anticipated expense of maintenance and repairs, I recommend homeowner install tank-type gas water heater:
Also install one-time-use whole house surge protector, and install grounding rods to prevent further damage... lightning frequently likes the same places over and again:
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
Gene
h
Aug 12, 2013 | Rinnai Water Heaters
Rinnai 20 heater stopping and starting have changed regulator but still not working properly only started playing up i have been in house 2 years any more suggestions
Single-handle faucet cartridge that leaks can cause tankless not to function. Check for crossover or cross connection:
http://waterheatertimer.org/Crossover.html
Cut losses from owning tankless computer that heats water. Go to Lowes and buy new tank-type gas water heater for $390 and have hot water right quick with less maintenance and own a product that homeowner can repair themselves.
Otherwise call service technician who is qualified to work on tankless computer.
Gene
n
Aug 07, 2013 | Rinnai Webstone The isolator EXP tankless...
How to fix Rinnai code 79
Let it dry out.
If it wont fire because of the error, try powering it off and back on. Also being new, it would be under warranty
Jul 20, 2013 | Rinnai Water Heaters
What does code 79 mean for the rinnai RU98i? It is beeiping and flashing 79
There is water leakage internally. Possible tank or water inlet or water entering from the combo air inlet/exhaust pipe.
Jan 09, 2013 | Rinnai Water Heaters
Rheem water heater manual model 81x52d
Our expert will provide you reviews regarding tankless water heater. If you are planning to purchase tankless water heater tank ,you must read about Tankless water heater from here. It will help you to know about which product is best suited for you. There are lots of reviews are available for you about different products.
https://tankless.review/rinnai-tankless-water-heater
Jun 03, 2012 | Rheem Water Heaters
Water Heaters Logo
1,584 people viewed this question
Top Rinnai Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
