Question about Lumens LM 136 Multimedia Projector
Manual user image is blurry and consequently can locate "focus in the menu. need instructions
How to focus my document camera
  1. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  2. If your Camera has Auto focus, Press the auto focus button on your document camera's control panel.
  3. Reset your camera to Default by Pressing MENU > Default > Yes > Enter. Then Power-Cycle your camera.
  4. Check your output device's focus adjustment.
  5. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  6. If Manual Focus adjustment is available on your camera's remote control, try adjusting back to focal point from the remote.
  7. If your camera has a Manual focus knob, manually adjust the focus by turning the focus knob located on the camera head.
  8. If adjusting the focus knob does not focus the image, please click here http://support.averusa.com/kb_article.php?ref=9869-UMJQ-1105 for instructions on how to fix the focus ring.
Feb 02, 2011 | Avermedia AVERVISION 300AF+ PORTABLE...
Flickering monitor
try changing the frequency to a higher value, (refresh rate) google for more info
Aug 28, 2009 | E-Machines eMachines Desktop PC
Blurry pictures
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory defaults as there could be a setting that is causing the images to be blurry. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset and press ok. Highlight yes and press ok. This will reset the camera back to factory settings. See if this clears up the blurry images.
May 03, 2009 | Olympus SP-560 UZ Digital Camera
Very soft focus on D200
Hi Amanda, welcome to FixYa.
Try this to fix your focusing issue. It's a custom AF setting.
Press the Menu and select the pencil icon. Then you'll see Custom Setting Menu on the LCD display. Click down to Autofocus and then click to the right.
There are 3 choices here: FPS Rate, FPS Rate + AF, and Focus.
Set it to Focus.
FPS Rate is the default setting, the camera will take 5 frames per second whether it's in focus or not.
FPS Rate+ AF forces it to slow down hoping to get more frames in focus.
Focus sets the camera to fire only when in perfect focus. It slows you down some, but it will save you from deleting all the blurry ones.
Try this and let me know if it works for you with a comment.
Ken Rockwell has alot of tips and tricks (including the one I just gave you) in a pdf telling all about your camera. You can read it here. http://www.kenrockwell.com/nikon/d200/users-guide/d200-users-guide.pdf
Enjoy your camera and feel free to rate my solution.
Rob
Mar 02, 2009 | Nikon D200 Digital Camera with 18-200mm...
Access to menu on sony cyber-shot DSC-T9
You can download Instruction Manual / User Guide of DSC-T9 from Sony Support and will get to know every thing about this camera.
Jan 07, 2009 | Sony Cyber-shot DSC-T9 Digital Camera
Service menu instructions needed
service menu code is 9876, i think. and you can manually adjust the focus using network54's post on "blurry z27x22d".
Sep 16, 2007 | Zenith Z27X22D 27" TV
Blurry Pictures
Contact Customer Support this is possibly a CCD problem- they may still fix it.
May 29, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
ProScan PS56700 completely out of focus / blurry
I would replace the EHT unit as the focus voltage is supplied from there, if it has not been twiddled with by unskilled personnel.
May 08, 2017 | Proscan PS56700 56" Rear Projection...
Blurry screen
Sounds like focus is out. These projectors are like cameras; they have an optic with a focus ring. Try rotating the focus. Some have electronic focus as well. If the manual focus does solve the problem, look through the menu for a focus setting adjustment.
Dec 26, 2006 | InFocus ScreenPlay 4805 Multimedia...
Camera Problem with Toshiba TLP 261
hi Document camera image is blurry: -The lens is dirty - Clean the lens with a blower or lens cleaner -The picture is out of focus - Focus the picture by turning the focus ring -The light is not on - Turn on the light check user manual for more details: http://www.fixya.com/BrowseManual.aspx?mnlid=5662&prdid=147420&__PAGED_=1 good luck
Mar 27, 2006 | Toshiba TLP 261 Multimedia Projector
Lumens LM 136 Multimedia Projector Logo
13 people viewed this question
Top Lumens Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Lumens Office Equipment and Supply Expert? Answer questions, earn points and help others
