I am looking for a nozzle to go on the tube end
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
Which tube on what make and model air conditioner?
Posted on Jul 20, 2013
Is difficult to fill gas tank
Gas pump nozzles have a device in the end that when gasoline runs back up into it, it turns off the fuel flow." There's a tiny hole near the bottom of the gas pump nozzle connected to a small tube.
Normally, air flows through that tube while you're filling and the gas keeps flowing as long as you hold down on the trigger. When that hole gets covered by gasoline (when your tank is full), a vacuum forms inside the nozzle and an automatic shutoff switch gets tripped, turning off the flow of gas with a thunk. Next time your fueling up try to reposition the nozzle.
Feb 26, 2014 | Chevrolet Cars & Trucks
Windshield washer fluid not spraying
Sounds to me part of the tubing is frozen shut from the pump to nozzle, nozzle may be clogged as well. The pump motor might run, but pump on the end faulty. Remove tubing from pump and see if it squirts out, if so replace tubing to pump and remove tubing from nozzle on hood or wiper, check to see if it squirts from there. IF it does then your nozzle is clogged with wax or ice.
Dec 16, 2013 | Hyundai Cars & Trucks
Keurig coffeee maker will not brew a full cup
I had this problem and it was due to a clogged nozzle. Open the pod holder and look up at the silver tube that punctures the top of the pods. Use a paperclip end and shove it up into this tube to clear out stuck coffee grounds. You should be good to go.
Aug 29, 2013 | Echo Garden
Detergent won't go through siphoning tube
it will only draw detergent with the large black nozzle or the nozzle wide open with not draw with high pressure
May 20, 2012 | Honda Black Max 2600 PSI Pressure Washer
My duet washer is leaking beacuse the seal is not aligned right, the metal ring that holds the seal in keeps popping ou..any advice?
Carefully pull the nozzle from the window washer tube. Separate the plastic gasket ring from the nozzle. Insert the nozzle through the hole in the boot and slide the plastic gasket ring down the shaft of the nozzle so that the boot is securely trapped between the gasket ring and the nozzle ridge. Insert the nozzle shaft into the window washer inlet tube and insert the end of the water inlet tube into the boot. Fit the boot around the front lip of the tub so it rests smoothly and evenly. Fit the boot clamp around the front lip of the tub and tighten the screw. Be careful not to over tighten this screw. Damage to the boot clamp or the boot could occur.
Jan 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do i insert the caulk and how do i use the gun
Cut the end of tube on a angle.There should be a rod with what looks like a plunger at the end.pull the rod back as far as it will go and lock into place.slide tube of caulk into gun with open end of tube towards the plunger.should be a slot at other end where nozzle fits in.take a piece of wire and poke a hole up the nozzle of the tube.release the rod and sqeeze the handle a few times you should see the rod start moving.if not turn the rod until the teeth are facing down.then try again .you should hear a clicking sound and feel pressure and caulk will begin to come out of tube and you will be caulking.Good luck.If you still have problems just come back to fix-ya and we,ll help you through it.
Dec 03, 2010 | Stanley Garden
Missing parts
Contact BISSELL they should be able to get you going
Aug 28, 2009 | Bissell 1631 PowerSteamer ProHeat Canister...
Fit new rear 'windscreen washer nozzle' on 2003 Accord
IF YOU CAN HOLD HOSE FROM BACK SIDE WITH FINGER TIPS AS CLOSE TO EXIT HOLE POSSIBLE, I THEN USE WHAT LOOKS LIKE A DENTISTS METAL TOOTH PICK ONE WITH A SLIGHT HOOK ON END(CAN BE BOUGHT AT ALMOST ANY TOOL STORE FOR A COUPLE BUCKS) THEN WILL HOLDING HOSE FROM BACK I STICK HOOKED END OF PICK INTO SIDE OF HOSE WHICH ALLOWS YOU TO PULL BACK THROUGH HOLE. YOU THEN CAN USUALLY PULL AN INCH OR TWO OF SLACK IN HOSE ALLOWING YOU TO CUT BROKEN PLASTIC PIECE IN HOSE RT OUT AND INSTALLL NEW KNOZZLE
Jan 04, 2009 | 2000 Honda Accord
Need new steam tube
Try this: http://www.smallappliance.com/product.asp?cur=USD&sid=18954&gid=18960&mid=15&pid=7108&prdCls=P&shopBy=Brand
Jun 16, 2008 | Krups Palatino 905-42 Espresso Machine
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
