Model #ACQ128XRO how many btus is this airconditioner
What is the tonnage on 48TME007-501
My guess is 4 tons. The 48 at the beginning of the model number could mean 48000 btus and with 12000 btus per ton that would mean 4 tons. Without a product name that's as good a guess as I can give. Good luck and hope this helps.
Oct 07, 2014 | Heating & Cooling
How can I determine btus & AFUE in a comfortmaker furnace, based on the model #?
The BTUS are part of the model number and the Manufacturer will give you the AFUE rating or just call a local comfortmaker wholesaler listed locally. Good Luck
Aug 14, 2013 | Heating & Cooling
Im just trying to find out how many btus my air conditioner is
It says it in the model number 12000 btus or one ton enough to cool 700 to maybe a thousand feet.
Jul 08, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I need to know kilowatt of fire - serial number
3412.1416 btus = 1 kilowatt , so it should have the btus near the serial number , but with no name or model number , thats all you can do
Mar 05, 2010 | Heating & Cooling
I had two very different quotes for installation. They recommended different models and different blowers. 15k vs 17k mxz4a36na vs mxz3a30 model. By getting the less expensive model and smaller blower...
The last two numbers in the model number indicates the Btu ratings. The mxz4a36 indicates that this unit is capable of putting out 36,000 Btus and only 30,000 Btus on the other. I would be concerned that the second unit is large enough to satisfy your cooling load. Forget the power, make sure the unit is sized properly.
Nov 11, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Need to know the BTUs on stovetop Burners
BTU ratings are usually the Model Number plate which is located in one of three places for Maytag:
1-Underneath burner top if top lifts up easily
2-On left lower front edge of frame with door open
3-Left edge of front oven frame with drawer open
Aug 23, 2009 | Kitchen Ranges
What is tht tonage if i have a model#wpka 031jaz weatherking air conditioner
2 1/2 T the 31 in the model # is 31,ooo btus divide by 12,000 btus in a ton
Aug 06, 2009 | Weather King 10AJA3601AH Air Conditioner
What's the BTUs for a Frigidaire window AC, model A1838?
it is in the model number a (18000 btus)38 this is a 1.5 ton.
Apr 23, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
