Question about Transcend Electronics - Others
Volume label 4gb - Transcend Electronics - Others
  • Lawrence Oravetz Jan 20, 2014
    Hi reina jea ninp, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
How do i change volume
Go to settings and the go down to sounds change the volume there.
Feb 13, 2015 | Visual Land 2.0"" Black 4GB MP3 / MP4...
I am converting Fat to NTFS convert l:/fs:ntfs the drive is 2gb what do i enter for the volume label for that drive
You need to locate the current volume label on the drive.
The easiest way to do this is from the command prompt, you type in vol(space) then the drive letter you are converting & press enter. It will then tell you the volume name, and then on the second line the serial number for the drive.
Oct 07, 2014 | Microsoft Windows 7 Ultimate for PC
Volume label
Right click the drive in My Computer, select Properties and use the "General" tab to change the volume name. Click <OK> and you should be all set.
Jan 23, 2014 | Kingston 4GB Secure Digital High Capacity...
Memory card 1GB volume label
My Computer. Right click Format > Volume Label.
My Computer. Right click Properties > Volume Label.
Start > Run / Search. Type cmd ENTER. Type label x: [name] x being the drive letter.
Nov 05, 2012 | SanDisk 1GB microSD Memory Card
My usb imation 4GB PB1 is not format
1.) Plug it into a computer.
2.) On the computer, go to Start, then Control Panel.
3.) When the Control Panel opens, go to Administrative Tools, then Computer Management.
4.) On the left-side panel of the new window, click on Disk Management. It will take a moment to load something in the middle panel.
5.) In the bottom portion of the middle panel, scroll down until you find the Defender. Right-click on it, then select "Format" from the list.
6.) A small window will appear. Where it says "Volume label," type in what you would like to name the device. For the file system, select "NTFS" from the pull-down menu. Leave the "Allocation unit size" as default. Then click the "OK" button.
7.) It will take a moment, but then it should be formatted for you.
Oct 14, 2012 | Imation 4GB DEFENDER F100 FLASH DRIVE USB ...
My USB says that it is 4gb, but when i go to properties, it says that over half of the space has been used, yet there isnt anything in my USB!!!???
Hello...Pal! You will have to format your disk using your computer so that it works properly. You have two options to format for micro sd card. One is, you are to open my computer and right click on the sd card drive and choose format option. This will display a window, there is a option of quick format, make a check sign to this and press format button. Second is, go to start menu -> Program Files -> Accessories -> and choose command prompt. when command prompt window opens, type e.g, "format K:" and press enter, if it ask for volume label, type its drive name like Personal (C:), only type the name e.g, Personal, and if it does not ask for volume label, press enter one more time, then this will show a surity message, type Y and press enter, your micro-sd card will be format successfully.
Oct 25, 2009 | Kingston 4GB Secure Digital High Capacity...
I cannot access my transcend pen drive
try changing the volume label at disk management on device manager
Aug 20, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How do i format my sandisk cruzer mini 4gb
To format this device better if you connect it to your computers USB port and let first the computer to recognize it, then when its already recognize by the computer double click Mycomputer icon and you should see there sandisk , just right click on it then click on format.....
Oct 27, 2008 | Computers & Internet
Electronics - Others Logo
44 people viewed this question
Top Transcend Electronics - Others Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
