Question about Cisco - Linksys Wireless-n Home Router - Black (wrt120n)
Ssid number wrt120n - Cisco - Linksys Wireless-n Home Router - Black (wrt120n)
    Problem Solver:
  • 14 Answers
I'd guess you want to change it? Log into it via the hardwire connection (usually 192.168.1.1), enter the admin and password (the defaults, I'd bet you never changed them), then go to the Wireless area and you can change the SSID. You can also change the password in the Security area, and you probably should.
Posted on Jun 02, 2014
Ssid in vizio
SSID
log into router and check what it is and if it is broadcasted.
May 20, 2014 | Linksys WRT120N Router
How can i block intruder?
If the Wireless device isn't secured, Secure it. Set up a SSID and Security Key(password). If it is secured, change the Security Key(password), Use the Linksys Setup Manual found here: http://support.linksys.com/en-us/support/routers/WRT120N Always Secure your Wireless. If unsecure your signal, at best, COULD be use by anyone to connect to the web using your resources and slowing down your activity. At worst, use your signal for nefarious purposes causing you a great deal of Pain and Heartache, and MAYBE the FBI knocking at your door.
Mar 20, 2013 | Linksys WRT120N Router
Need the security code for the WRT120N wireless router so that I can connect to my Smart TV.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Dec 02, 2012 | Linksys WRT120N Wireless Router
What is the security code for the WRT120N router
IF you don't know the password to your router you will need to reset the router by sticking a pin or toothpick into the hole on the back label reset and re-configure your router.
Dec 02, 2012 | Linksys WRT120N Router
Linksys wrt54g2 v1.5
Test connection with network cable working your way backwards to modem or main drop. Then reset at point of failure.
Nov 26, 2012 | Linksys WRT120N Router
WRT120N ROUTER TO KINDLE FIRE
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
http://192.168.1.1
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 29, 2012 | Linksys WRT120N Wireless Router
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
How do I reset my WRT120N
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
http://192.168.1.1
You can protect your router by changing the default PW (write it down and putit in a safe place)
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 13, 2011 | Linksys WRT120N Router
I set up my WRT120N router. My desktop is connected to the internet with the provided ethernet cord, but my friend's macbook cannot connect wirelessly. He keeps getting a "timeout" message. ...
You Linksys wireless settings ie. SSID and encryption etc these settings are needed to configure the wireless card in the MAC so it can connect to the Linksys.
Dec 04, 2010 | Linksys WRT120N Router
Cisco - Linksys Wireless-n Home Router - Black (wrt120n) Logo
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
