Question about Whirlpool Heating & Cooling
How many btus are in air condtioner whirlpool 44r261a
Whats the tonage of this condenser
Tons of cooling or heating are done by btus.
So 6000 btus is 1/2 a ton,12000 btus is 1 ton.And so on.
You need to get the total btu rating off the unit then figure it out.
Dec 29, 2010 | Heating & Cooling
How can I tell if the fuse is blown inside my window air condtioner?
window air conditioners do not have high voltage fuses. You should have the outlet going to a dedicated fuse/breaker on your house power panel.
If your unit has a digital display that circuit will have a low voltage fuse. This is common design with all window units that I have seen the last 28 years.
Jun 19, 2010 | Whirlpool Heating & Cooling
How can we caculate the energy needed by an air conditioner?
It depends on the (EER) Energy Efficiency Ratio,which is capacity divided by watts.
Example 35000 btus / 2500 watts = 14 EER
If you know the capacity,btus and EER you can calculate the watts, capacity / EER
Example 35000 btus / 14 EER = 2500 watts.
EER is determine by testing the air conditioner at Department of Energy Guidelines, which are
80° drybulb 67° wetbulb indoor and 95° and 82° drybulb outdoor.
May 14, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
What's the BTUs for a Frigidaire window AC, model A1838?
it is in the model number a (18000 btus)38 this is a 1.5 ton.
Apr 23, 2009 | Heating & Cooling
My air condtion blow some hot air with vabrait what shall i do ?
you need to recharce your air conditioner system with refridgerant. you may have a small leak that depletes the system over time.
Mar 16, 2009 | 1999 Daewoo Nubira
Drainage
No drain but has a drain pan ac87397.tif
Jun 29, 2008 | Whirlpool ACQ108XL Air Conditioner
Heating & Cooling Logo
190 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
