Question about Samsung Remote Control DB93-03012B p/n:DB9303012B
Settings The remote is not working with the Air Condition
My remote control is not working i have fujitsu air condition model #AR-RY6 can i use different model ?
There are some other Fujitsu models that will work but not all. The remote controls from Fujitsu themselves are not too expensive if you want a genuine one. Call them for a replacement or try a cheap universal remote from somewhere like ebay or Aliexpress.
Oct 15, 2016 | Fujitsu Heating & Cooling
My remote control is working i need replacement is for fujitsu air condition model #AR-RY6 or can i use different model
I find that most remotes from the same manufacture work on different models. Fujitsu is big enough where I think its worth a try.
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Nov 16, 2012 | Heating & Cooling
How do you get the air condition to work in 2010 traverse
First thing to do is have someone check the compressor to see if it is running with the engine and ac control on.
Jul 05, 2012 | Cars & Trucks
Air condition switch not working on settings one and two for 2001 chevy silverado
I think it would be the blower resister for 1 / 2 spped circut (open circut)
Jun 19, 2012 | Cars & Trucks
I just buy an lg aircondition with remote when 1 of my family member accidentally throw out the manual and the remote...please help...what should i do to have new one?
Call Lg and have the model number of your air condition. They may send you one for free if you explain what happened otherwise you may be charged. Also go to where you bought the air condition and they may have generic programmable remotes to work with your lg air conditioner.
Aug 17, 2010 | LG Kitchen Ranges
Air conditioning unit is not responding to the remote
If you can't change the settings manually, then the control pad is bad. If you can and the remote won't change the temp or mode then the remote is bad and will need to be replaced.
Apr 10, 2009 | Heating & Cooling
Remonte controls for Hisense air condition
hi , you can bring a universal remote and this one can work for many air conditions look at the codes for the kind of ac.
Feb 16, 2009 | LG LSC091PMA Split System Air Conditioner
Air condition won't work
THE CLICKING SOUND IS A RELAY PULLING IN ITS LIKE A SWITCH CONNECTING TWO WIRES. THIS IS A GOOD SOUND BUT IS USALLY FOLLOWED BY SOMETHING COMING ON FAN ETC... CHECK TO SEE IF YOUR UNIT HAS AN LED LIGHT ON IT AND HOW MANY TIMES IF ANY DOES IT BLINK?
Jun 08, 2007 | GE AGM24DJ Electronic Room Air Conditioner
Samsung Remote Control DB93-03012B p/n:DB9303012B Logo
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
