Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Oven Heat I have a Kenmore 911.93402991 model electric oven/range. The oven heats to desired temps but wont shut down after oven knob has been turned to OFF. Have to shut off circuit breaker to shut off oven. Rest of stove is OK functionally. What's happen'in? Thanks, AL
  • Theresabr Nov 26, 2007
    my oven over heat how I can repair this?
  • Anonymous Mar 30, 2014
    oven has low temp
  • 640 Answers
THE OVEN SWITCH IS BAD ITS STAYING CLOSED.FAIRLY EASY TO REPLACE AND NOT THAT EXPENSIVE.ANY APPLIANCE STORE CAN ORDER THE PART OR YOU CAN FIND IT ONLINE.
Posted on Aug 29, 2007
SOURCE:
Whirlpool estate electric range model heat oven
there is also a temp sensor inside the oven that could be faulty
Sep 19, 2013 | Whirlpool GS440 Gas Kitchen Range
Kenmore wall oven model 911.4088816
i believe this oven was designed to reach a set temp and then interm shutdown to keep that set temp..If oven elements turn back on when temp is raised higher than previous temp ..then there is a good chance its working properly.this is a saftey feature to keep elements on stove from overheating..
Dec 18, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
Oven will not heat over 200
oven does not heat to desired temp we have used a oven thermometer and most of time oven is at 350 but thermometer is at 275 than up to 325 and then down again to 225
Jul 09, 2012 | Viking Professional VGRC365-4GD Stainless...
Fan in range continues to run after oven is cold.
Is oven COLD, or still cooling down after you shut it off? If the latter, some ovens do that, untill they reach a pre-determined temp THEN shut off. They are made that way dissapate the heat.
Mar 31, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
I have a GE Hotpoint flat top stove model # RB787WC1WW and the oven will sometimes shut off by itself. Is there a sensor that shuts it down when it reaches desired heat. It will sometimes turn on if you...
That is what the oven elements are suppose to do. When it gets to temp the thermostat cuts the elements off and as it cools they will heat back up. if it cuts off and wont heat back up its probably the thermostat
Mar 08, 2010 | Hotpoint RB787 Electric Kitchen Range
Kenmore oven model #9119359181 oven temp will go
check heat sensor. probably needs to be replaced
Dec 01, 2009 | Kenmore Kitchen Ranges
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 29, 2008 | Magic Chef 9512 Electric Single Oven
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
334 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
