Question about Intel Q35/1333FSB/LGA775/DDR2 800/PCI-EX/AUDIO/uATX/RAID (BOXDQ35MPE) Motherboard
Compatible motherboards qx9770 - Intel Q35/1333FSB/LGA775/DDR2 800/PCI-EX/AUDIO/uATX/RAID (BOXDQ35MPE) Motherboard
What is the processors that can be compatible for Intel motherboard
Confirm your motherboard's compatibility with the Intel CPU you want to install. Motherboards typically only support one type of CPU slot, so purchase an Intel processor that is compatible with that slot.
Ensuring your processor and motherboard are compatible is vital when choosing parts to build your own computer system. If they are both the same socket type, they will most likely work together.
Brands
There are a plethora of motherboard manufacturers, but only two main processor manufacturers: AMD and Intel.
Every motherboard, regardless of manufacturer, has a socket that will accept a processor.
Intel
Common Intel socket types include LGA775, LGA1156 and LGA1366. Older models include PGA370, PGA423 and Socket 479.
Your motherboard and processor will be generally compatible if their socket types match. ...
Intel Core 2 Quad Q9650 Processor Compatible Motherboards
Hope this will help you and please don't forget to rate me. Thanks for using FixYa
Aug 02, 2011 | Intel Motherboard
Is the intel core 2 quad compatible with my ddr2 memory
Hello.
The motherboard ASUS P5KPL-AM SE is compatible with DDR-2 no matter what processor you are using, even Intel Core 2 Quad. So if that is your motherboard, then it is compatible.
Jul 20, 2011 | ASUS P5KPL-AM SE Motherboard
Can I replace My motherboard with another model laptop motherboard. Example....HP Vs. Fujitsu Siemens compatible or Dell or something. Thanks
Hi, Well you can change with te compatible motherboard but it will not be giving you the exact performance and it is risky to replace laptop motherboard with another motherboard. Try to replace it with the original vendor because there are brands which says that these are compatible but often they are not compatible to each other so i will advice you to go for the original vendor and not for the other vendor.
Regards, polysandy
Apr 22, 2010 | HP Compaq 6720s Notebook
Gigabyte ga-81915 pmd motherboard/precott 3.6 cpu/upgrade cpu?
the best and cheapest up grade is RAM.
Make sure you have all the memory your machine can handle.
A quick look say it can handle Core™ 2 Extreme QX9770(3.2GHz,12 MB)
And it has a PCI-express slot so you have a big chiose of video cards.Are you using the machine for gaming?
Jan 10, 2010 | Intel Motherboard
Compatibility
Yes both of them are compatible, The 8500 GT uses a PCI X16 slot which is available on the m2n-mx motherboard.
Check these 2 links
http://www.amazon.com/Geforce-8500-Pcie-256MB-2PORT/dp/B000RKS3MU
http://reviews.cnet.com/motherboards/asus-m2n-mx-motherboard/4507-3049_7-32045049.html?tag=mncol;psum
May 14, 2009 | ASUS M2N-MX Motherboard
Ati radeon hd3800 conflicts with ram
just a shot in the dark here maybe you're power supply needs a little more power to support that video card + 8 gigs of ram + all other peripherals you use
Feb 24, 2009 | Intel DX48BT2 Motherboard - X48, Socket...
AMD or Intel Processor for desktop gaming and animation purpose
when it comes to new processors i would definatly suggest any intel from the core 2 series. AMD is having problems with overheating and has all but abandoned thier quest for quad core glory.
Jan 25, 2009 | Intel Computers & Internet
CPU compatibility
This motherboard is not compatible with a Dual core processor since this is a old Motherboard a;ready and only supports Intel Celeron, Intel Pentium 4..
Dec 31, 2008 | Soyo SY-P4I845PE Lite Motherboard
Intel Q35/1333FSB/LGA775/DDR2 800/PCI-EX/AUDIO/uATX/RAID (BOXDQ35MPE) Motherboard Logo
19 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
