Question about Baby Gear
Sounds like motor running but seat want move this is a 1984 pontiac Bonneville front power seat
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 12 Answers
Track for the seat might be broken and that's why you keep Hearing the motor running
Posted on Aug 07, 2013
Seat motor
it will be very hard to move
Apr 06, 2014 | 1997 Pontiac Bonneville
1995 Pontiac bonneville sea t belt chime won't turn off
sounds like a bad wire or sensor in one of the seats or connections. Check grounds and broken wires. Check inside connectors for blockage of some type.
Jan 27, 2013 | 1995 Pontiac Bonneville
Powerseat switch does not work on 1993 bonnivillehow to manually move seat or jump switch out
Get another switch from a junk yard. the seat will not move manually. If you're going to try to jump the switch it's easier to just replace it.
Dec 23, 2012 | 1993 Pontiac Bonneville
2002 Bonneville Sunroof. Fabric on sunshade was loose, was able to pull shade forward, glued fabric but the shade will not go back. Seems to be hitting something in the back. Can you help?
Hi
Inspect the sun roof of your Pontiac Bonneville to make sure it's seated evenly on your vehicle, not raising or lifting at one corner. Lifting indicates the presence of debris on the tracks, or a damaged seal around the sun roof.
Remove the trim on the interior of your Pontiac Bonneville and allow the interior material to drop. Use compressed air to blow dust and debris from the tracks that move your sun roof. Treat the tracks using 3-In-One Lubricant.
Check the Pontiac Bonneville's drain tubes for clogging. Two of these run down the front of your vehicle to the bumpers. Two run to the back, most often by your tail lights. Clear the tubes using compressed air and replace them.
Clean the sun roof's rubber seal with a damp, lint-free cloth. Inspect the seal as you clean
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 19, 2011 | Pontiac Bonneville Cars & Trucks
Where is the fuse box located in a 2003 Pontiac Bonneville?
There's a bunch of fuses under the rear seat.
lift the front of the seat straight up.
May 14, 2010 | 2003 Pontiac Bonneville
Where is the battery on a 2005 pontiac bonneville
i have a 2000 bonneville and my battery is located under the back seat on the passenger side. lift up on the front of the seat and it should pop up off of two metal clips and the battery should be under it
Jan 04, 2010 | 2005 Pontiac Bonneville
1994 pontiac bonneville
Remove and clean battery cables.
Jun 16, 2009 | 1994 Pontiac Bonneville
My drivers side power seat not moving but i can hear the power working when i hold the switch. fuses and circuit breakers good. why wont it move?
Had exactly the same problem. Hacked a solution, disconnected the flexible cable from the motor. Problem was the nylon drive gear was stripped. Just twisted the cable by hand to desired position ( wife's car) to fit her. Left cable detached and accessible under the seat if needed again. Big tussel getting the seat removed. GM has a very large strange torx screw holding the seat belt mount which has to be removed. Other strangeness the front 2 seat mount bolts were metric. The rear 2 were US SAE standard. Other strangness one bolt was never installed at factory ?? Was probably close to lunch time at the seat place. If you want to repair fully you should get a used ? motor as I think the wholw motor housing was rather crimped and built into th seat frame. That's probably why I did the "manual hack" works well for a year now. Now window motors are another sad story.
(inner door pannel is welded in place) need to cut for access - Dealer quited $500 - window is rather still closed.
Good Luck
Apeal
Jul 22, 2008 | 1991 Pontiac Bonneville
Power window trouble
THis is the problem with the power motor it might be jammed or broken get it replaced it will work..............
Jun 04, 2008 | 1990 Pontiac Bonneville
Baby Gear Logo
60 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
