Boot up isues with my LT2811u Netbook with Windows7
Power on it goes to prompt, thento windows boot manager, with 0xc00000e9 error.
    Top Expert:
  • 12,223 Answers
Run the software diagnostic coming with the computer. or download from the supplier company and test.
You can get support via ONLINE chat free.
God bless you
Posted on Jul 21, 2013
PCHelp4U
  • 13 Answers
SOURCE: I dropped my computer and now I get error An unexpected I/O error
Attempt to Re-Install Windows (most likely this will not work) if it does not then you need a new drive. The insides of the harddrive have shifted
Posted on Jan 11, 2009
  • 79 Answers
SOURCE: Windows does not boot up
This is likely your hard drive - this could be a drive error - in which case your drive is likely lost (and the data on it) I'm afraid. A technician would check the cables to your drive are ok. In laptops you can usually take out the hard drive under the laptop. If you can, do this, clean the connectors and plug back in. If that doesn't work then I'm afraid it isnt good.
Posted on Apr 10, 2009
haayz
  • 197 Answers
SOURCE: windows boot manager file: /boot/bcd status:
Try check your hard disk with the other machine. Try running hard disk diagnostic test. If there's a problem with diagnostic test i suspect your hard disk is faulty. If you tried connecting with other machine then same problem, suspected also hard disk faulty. You might need to change it.
Posted on Jun 02, 2009
jennifer720
  • 830 Answers
SOURCE: when i try to boot my toshiba it goes to a windows
Hello and thank you for using Fixya's services.
The only option here is to restore your computer to factory settings. You will lose all of your information including pictures, music, etc.
Are you running Windows Vista? If so, turn the computer on, press F4, choose advanced and you will see the option to do a factory restore. You can aslo try the other options first such as windows restore and it may fix the file.
Last resort is the factory restore but you are at that point.
Please let me know if you have any questions.
Posted on Nov 10, 2009
  • 429 Answers
SOURCE: aspire 5920 my computer has crashed and i cant get
Try alt f10
Posted on Mar 02, 2010
Asus oxcoooooe9 step by step instructions to fix would be great as I'm on a pension I can acess windows boot manager page and aptio setup utility page ( bios information) can I do something from there ???...
Error 0XC00000E9 code for Windows can be extremely broad and each number will represent a different problem. To be able to use these 'codes' to be able to fix what is wrong a good deal of investigation must be made.
Common causes of 0XC00000E9 error?
0XC00000E9 Error should not be ignored though as the eventual outcome can be the slowdown or total crashing of a computer if not fixed.
How to FIX error code 0XC00000E9 ?
Fixing Error 0XC00000E9 manually is a difficult process and it is not recommend unless you are an expert in this field.
Therefore, we recommend you to use Regservo. It is reliable PC Repair tool that can do all the hard work for you.
Please follow the 3 steps below:
(1) (Download 0XC00000E9 Repair Tool).
(2) Click the "Scan Now" Button. and wait for the scan to finish.
(3) Click the "Fix" button to fix all identified errors.
Note: Please make sure that you restart your computer after regservo fixes all your identified errors. I have never used this programme as I would repair myself but for the novice, this seems a good way around the hdd issue.
Feb 04, 2014 | Computers & Internet
Windows error 0xc00000e9
This error is sometimes an indication that the hard drive may be failing.Complete the following steps to check the integrity of your hard drive. If you are unable to get to the Advanced Boot Option menu using the F8 key, you will need to obtain a Windows Vista disc.
1.Restart your computer, tapping on the F8 button until you reach the Advanced Boot Options menu.
2.Select Safe Mode with command prompt.
3.Type chkdsk /r (there is a space between k and /)
Sep 12, 2013 | Dell Inspiron Computers & Internet
Computer won't boot stuck in Error RecoveryScreen won't go any further
You should be able to do a clean install of Windows. Just insert the installation disc and press any key when indicated. Optical drive needs to be the first boot option. Go into BIOS and change it is not.
As for disc, you have to use the same Windows version as indicated on the MS Product Key sticker, because of the serial number.
May 24, 2013 | Toshiba NB205-N210 Netbook
My netbook (Acer Aspire One Netbook ao531h) goes to blue screen on start-up it has an unmountable boot volume error, codes shown below: STOP 0x000000ED (0x86B5C470, 0xc0000006, 0x00000000, ...
Its the problem with hardware driver software. Please remove last installed software/hardware in your system. To remove software run system in safe mode by pressing F8 on system starting and select safe mode then remove last installed hardware by opening device manager or remove software by opening add remove program from the control panel.Then restart system.
Any problem came ask again new question
************************Please RATE it *******************
Apr 25, 2011 | Acer Aspire One Netbook AO531h-1729 10.1...
I have a dell 1525 inspiron when i turn it on it says windows error recovery when i try to start the computer it goes to windows boot manager it says insert your windows installation disc and restart your...
For that First when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set first boot device as your cd or dvd rom then save settings and exit.
Then it boot with your recovery disk.
Then follow the procedure and enter in recovery console mode.
Then type in prompt "chkdsk /r"
then press "y
then it fix error on harddisk.
Then check if still same error then again boot with disk then repair your windows .
Let me know if you need more assistance.
Thanks.
Oct 10, 2009 | Dell Inspiron 1525 Notebook
Windows boot manager page with status 0xc00000e9
If you don'yt have a Vista DVD,you can borrow any for startup vista repair. This is very common and HP/Compaq don't usually give operating systen vista dvd
Oct 02, 2009 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
