Question about Refrigerators
Daewoo fridge freezer
Have ordered two seals for my daewoo ERF335M had to send them back how much we tried they would not fit fridge.Freezer seal no problems dont know where to go from here.
applianceboy
  • 77 Answers
SOURCE: condensation problem hotpoint mistral 8596
if the door seals are both ok, check and see if she has any open containers in the fridge juice ect that may be allowing moisture to escape. a model number and serial nuber off the sticker in the fridge would help me with more ideas.
Posted on Sep 26, 2007
Amigaman
  • 248 Answers
SOURCE: refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Posted on Nov 12, 2007
SOURCE: freezer door won't stay shut
Adjust the front rollers so frig lean toward back and live with the results. From a GE tech
Posted on Aug 27, 2008
buddymcl777
  • 67 Answers
SOURCE: freezer door not sealing
replace the seals and / or have the hinge adjusted
Posted on May 01, 2009
  • 166 Answers
SOURCE: How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
This should help!
Brad
Posted on May 25, 2009
My Daewoo American fridge freezer is not making ice in the ice compartment and food have started to defrost but you can hear the fridge freezer working
How old is the fridge? If it is old I suspect the compressor is not functioning as it should. Things to check before calling the repairman or buying a new one: The thermostat setting. Be sure there are no air leaks around the door seals.
Jan 10, 2018 | Daewoo Refrigerators
My fridge/freezer is frosting cos the rubbers shot x local repairman says he will not fix as "it never works"x can I replace them myself? difficult? x leroy
most places have a " seal-a fridge " type business that comes to your place and makes and fits door seals to fridges and freezers
check in the trade pages of the phone directory or go google and type in--- fridge door seals and repairs -- to see if there is a business close to you
the only problem that you may have is , if the door and seal edge area is badly rusted
if you can get a seal from a service agent spares and you have some ability you may be able to fit the new seal your self
Nov 22, 2016 | Refrigerators
Hi I have a problem with my American style Daewoo
It sound like the door seal is damaged or the door itself might be loose.
Nov 04, 2013 | Refrigerators
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Hi my Asko fridge has a freezer compartment - I
not sure why the seal is faulty but yes you can buy a rubber seal for the door go to your local hardware store you might have to look in the section that stops drafts from entering a room or rubber flex material with a adhesive tape that can be formed into any shape eg around a outlet pipe or to seal a window etc and you can always trim some rubber sealer to fit if its a little large . I used a foam roll with adhesive tape to seal my freezer door on a mini bar fridge and its still in use today
Oct 26, 2017 | Refrigerators
My Daewoo FRS2021IAL has a warm fridge
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 26, 2009 | Daewoo Refrigerators
Freezer door of electrlux freezer keeps coming
Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
Jul 06, 2009 | Freezers
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
