Question about Dryers
Cinni fan Hi, the swinging mechanism of my Cinni is malfunctioning. When it rotates to the right side, it stays there and refuses to rotate back to the left. Is this something that is easy to repair? Thank you in advance. Chris
sonyspares
  • 89 Answers
SOURCE: LCD Display
The flexible LCD film connecting strip is defective. I think this is fused to the LCD and you need to replace the whole unit.
Posted on Dec 01, 2006
IFIXALL
  • 868 Answers
SOURCE: rotate the doors
You can reverse the doors and it is not very hard to do.If you need assistance I'll be happy to provide the help to do this.
Posted on May 14, 2008
  • 113 Answers
SOURCE: kenmore 80 series washing machine agitator will not rotate
you need to replace the agitator dogs, very simple. Go to www.shop.washermd.com and download the tutorial, thanks
Posted on Mar 03, 2009
  • 48 Answers
SOURCE: ceiling fan some time not rotating
First note that there are often two switches: one on the wall of the room with the fan and one on the fan itself. If that doesn't solve the problem, there may be an electrical problem and the fan may need service (it could even need lubrication if it is stuck from a long period of non-use). Also note that electrical problems can cause fires, so it may be necessary to get the fan fixed by a competent service person. Hampton Bay is a pretty good brand but nothing lasts forever and most of us tend to use fans for months and months without servicing them.
Posted on Apr 13, 2009
woobie dog
  • 1273 Answers
SOURCE: sqeaky fan rotation
Try oiling the pull bearings. If you can determine that the noise is in the motor, try nelsonappliance.com. They have replacement motors for your fan for less than $20.
Regards, --WoobieDog--
Posted on Jul 10, 2009
Why doesn't my fan rotate anymore?
definitely sounds mechanical. try prying open the motor area and see if anything happens when you turn it on. i'm guessing it might be a short somewhere that's making the other parts have to compensate
also check into servos, relays, and whatnot
May 15, 2015 | Miscellaneous
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Broken cinni pedestal fan
rattling fans are an indication of unbalanced fan blades. check for dirt or corrosion on blades Remove the blades and see if the motor still vibrates. If so scrap the unit. You may be able to get new blades but as few places carry fan spares I would hold out hope in that department. Check around the appliance repair shops and see what info you can dig up . May be a contact to the manufacturer on the web will give some answers as to spares
Jul 14, 2013 | Cars & Trucks
Information needed: Celsius WF-604 Air Cooler - Their are 2 Push Button Switches on the cooler the: The Cool Push Button Switch and the Swing Push Button Switch. This creates a total of 4 sets of...
The on/off COOL switch controls the moving pad (on rollers), when ON the pad rollers rotate and pull the pads around in a circle. Pad picks up water at the bottom and evaporates water at it rises, thus it is an evaporation cooler.
The on/off SWING switch controls the oscillating louvers which can be stationary or moving left and right. It directs the air flow from straight ahead to the sides.
Either can be on or off.
The Speed controls switch, which you did not mention, determines how fast the fan blades will spin.
Aug 21, 2011 | Heating & Cooling
Describe your how fix my pontiac 2000 montana Problem changing spark plugs
Inspection
Inspect for the correct routing of the spark plug wires. Improper routing may cause cross-firing. Inspect each wire for any signs of cranks or splits in the wire. Inspect each plug wire boot for tearing, piercing, arcing, carbon tracking or a corroded terminal.
If there is any corrosion, carbon tracking or arcing indicated on a plug wire boot or terminal, both the plug wire and component it was connected to should be replaced.
Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove the left side spark plug wires from the spark plugs.
  3. Remove the left side plug wires from the retaining clips.
  4. Rotate the engine for access as follows:
    1. Set the parking brake.
    2. Shift the transaxle into neutral.
    3. Remove the engine mount strut bolts. Swing the engine mount struts aside.
    4. Install the Engine Tilt Strap J-41131.
    5. Pull on the engine in order to rotate the engine forward.
    6. Tighten the strap.
  5. Remove the right side spark plug wires from the spark plugs.
  6. Remove the plug wires from the retaining clip.
  7. Remove the spark wires from the ignition coils.
  8. Remove the plug wire assembly from the engine.
    NOTE If you are replacing the spark plug wires, the spark plug wire conduit and retaining clips should be transferred to the replacement wires.
To install:
  1. Install the right side plug wires to the ignition coils and then the spark plugs.
  2. Install the spark plug wires to the retaining clip.
  3. Rotate the engine back to the original position.
  4. Install the left side spark plug wires to the ignition coils and then to the spark plugs.
  5. Install the spark plug wires to the retaining clips.
3.9L Engine
  2. Remove the intake manifold cover.
  3. Remove the left side spark plug wires as follows:
    1. Disconnect the left side spark plug wires from the spark plugs.
    2. Disconnect the left side spark plug wires from the ignition coil.
    3. Remove the left side spark plug wire clips from the intake manifold and heater inlet and outlet pipe.
    4. Remove the left side spark plug wire assembly.
  4. If removing the right side spark plug wires, the engine must be rotated for access as follows:
  5. After rotating the engine, remove the right side spark plug wires as follows:
    1. Disconnect the right side spark plug wires from the spark plugs and ignition coil.
  6. Remove the right side spark plug wire clip from the ignition coil bracket.
  7. Remove the right side spark plug wire assembly.
To install:
  1. Install the spark plug wire assembly.
  2. Install the right side spark plug wire clip at the ignition coil bracket.
  3. Connect the plug wires to the ignition coil and spark plugs.
  4. If the engine was rotated for access, return the engine to the original position.
  5. The remainder of the installation is the reverse order of removal.
Feb 05, 2011 | 2000 Pontiac Montana
When i turn on my protron 42 inch plasma it will stay on for like 5 to 10 mins then it turns off
hi,
may be the fan inside ur tv is not functioning. because there is some parts in side ur tv which need colling, so fan is necessary. u can do the following by your self. just check it.
remove the power . just open ur tvs back cover . find out the fan. normally it may be in top left and right side .it will not runs if it is staked because of dust inside it. remove the fans. try to rotate its leaf, it should run freely. if not clean it. remove the specification sticker on the fan. and put on or two drops of oil in it bearing . rotate it leafs with ur finger until it runs free, then fix it and try again. if it says fan problem again just replace the fans.
if u need any further assistance feel free to contact me through fixya.
ok
Dec 14, 2010 | Protron Televison & Video
Tire rotation pattern
Right front to right rear, left front to left rear. Left and right sides are NOT to be switched. Left stays left,right stays right. The "x" pattern is a rotation pattern of the past,you never what to upset the rotating rotation of the tires when they were first placed on the vehicle.
Jun 13, 2010 | 2005 Toyota Corolla
3 speeds settings - only 1 speed and that is fast
I believe that your fan speed selector is bad.
Jul 02, 2009 | Heating & Cooling
I have not worn my SEIKO kinetic wrist watch for a
Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
Jun 05, 2009 | Seiko Kinetic watch
My tall Cinni standard fan isn't working. When you switch it on you can hear the motor trying, but the fan blades don't move at all. It's boiling today in my office, so we'd like to know what might be up...
Stage 1: unscrew 2No. top and bottom nut/bolt put to one side, lift 4No. hinge clips and remove front cage.
Stage 2: partially unscrew spindle screw on fan body then slide fan off spindle.
Stage 3: plug in fan turn to setting '1' (lowest setting, the motor will hum but not rotate) now with a hammer 'carefully' tap the spindle so that it is aligned within the housing, it may need to lo left, right, up, down whatever direction it needs to sit centrally withing the bushes of the front and rear housings. Then tap the end of the spindle which sometimes re-engages/realigns the spindle within the rear bush.
Stage 4: reverse of stage 2 & 1
Good luck
Jul 01, 2008 | Heating & Cooling
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
