I want a hand book for the agfa 1500 slide projector
45 year old Slide projector
Ask around your local photo shops for a guy with a long grey beard to ask.
You could try advertising for an instruction book on your local freecycle and if Hanimex is still in business they might help you.
Some of those slide projectors were intuitive as they were completely manual but there were also magazine load, semi-auto and fully automatic versions that could also have a recorded commentary and backing music synchronised to the slide show.
Best of luck friend, have lots of fun with it.
Sep 04, 2015 | Office Equipment & Supplies
Kodak Carousel 600 Slide Projector manual
The KODAK Carousel 600 Projector has NO forward or reverse controls. To cycle the tray forward, LIGHTLY depress the SELECT bar. Reverse is accomplished by holding the SELECT bar down completely and rotating the tray by hand. Jim
Apr 03, 2013 | Kodak Carousel 600 Slide Projector
Kodak 600 projector has not advance button
You're correct!! The Kodak Carousel 600 does not have an ADVANCE button. To advance the tray you LIGHTLY depress the SELECT bar on the edge of the projector. There is no reverse capability, other than holding the SELECT bar down fully and rotating the tray by hand. Enjoy your projector!! Jim
Mar 09, 2013 | Kodak Carousel 600 Slide Projector
How to change kodak carosel projector ektanar lense
The projection lens will can easily be removed by pushing the focus knob toward the slide tray with one hand while pulling the lens out of the projector with your other hand.
Aug 02, 2012 | Kodak Office Equipment & Supplies
All slides are fuzzy on my hanimex Rondette 1500 RF
If it is fair to make the assumption that the projector focussed slides correctly in the past,m then here are my suggestions:
- More than likely there is probably one of the optical components missing or out of position.
- The other thing that could be affecting focus is that the projector is too close to the screen, I would open the compartment where the optical components are located and check for proper position and cleanliness.
Good Luck !! jim
Apr 18, 2011 | Vivitar V5000AF Slide Projector
The slides appear to be dropping to far down so when viewed you see the top of slide (cardboard) and top half of picture- thi swas given to me used and I dont have a book - it is 300AF
Try using a full thickness plastic slide mount. Some card slides are so thin that they miss the slide support when being dropped down from the magazine. Some magazines are designed specifically for card mounted slides whilst other are for glass mounted slides. Types shouldn't be mixed for correct and consistent operation.
Feb 14, 2011 | Elmo Projectors Omnigraphic 301 Slide...
I need the power and connection wire specifications for arcusII agfa scanner.
My Arcus II is 20 years old. I don't know when Agfa stopped servicing their scanners. Mine uses scsi connections and it's connected to Mac G5 OS 9. My driver is Fotosnap. I have the original book and loose leaf.
Feb 10, 2011 | Agfa Arcus II Flatbed Scanner
I have Hanimex Rondex 120 rotary magazines. I was told these would work in the Vivitar 5000AF. Is this true, as the slide on mine is jamming on the return?
I have a VIVITAR 5000 AF slide projector.
Occasionally, the slide gets stuck while operating the mechanical hand to change the slide. Most of the time it works when I push the slide carrier by hand. Very very infrequently, the projector actually throws out the slide.
I have ascertained that teh Kodak slides which are mounted on paper frames are much too thin for the mechanical hand pushing teh slide in and out. The solution is to remount teh slides on palstic frames or some how add to the thickness of the slide. I have not tried it yet , though.
Any more ideas?
MNAQUVI@yahoo.com
Jan 23, 2011 | Vivitar V5000AF Slide Projector
Epson projector from computer & powerpoint
You need a wireless presentation remote that has a transmitter that plugs in to the back of the computer. This can be used to advance the slides. Make sure you get one that states the distance you need.
Let me know if that helps.
-Jeff
Aug 23, 2008 | Epson - PowerLite S1+ Multimedia Projector
42 people viewed this question
k24674
jasbo
jasbo
