My tv got knocked over now it won't turn on
Last night my cat knocked over my flat screen tv and it shut itself off, now we can't get it to turn back on, it took a pretty hard fall. Is there any way to fix it?
domotek
  • 591 Answers
SOURCE: Hi my tv fell off
After a fall like this (even on carpet) it probably has a cracked circuit board or a loose connector, first (since you took it apart any way) look for all connectors, than unplug them and re-plug them to make sure all plugs and boards are seated correctly, if you still don't have luck, than take out all the circuit boards and check them for cracks under a good lamp and magnifying lens, than repair the cracked traces with a good soldering gun by scratching off the varnish coating and applying solder. (if the crack is to wide you can solder a peace of coper wire to the trace on the board)
Have fun!
Posted on Jun 25, 2011
Testimonial: "Thank you for the response what circuit board the power board? I I was to change that out how would I make it safe not to shock me "
  • 12 Answers
SOURCE: tv troubleshooting
There is problem in the power Supply section.check the h-out Transistor if Damage then Change for the Same COde #
Posted on Nov 13, 2008
SOURCE: my GVA LCD flat screen TV switches itself off as
My flat screen will not turn on the green light flashes for a while then stops
Posted on Mar 03, 2010
SOURCE: tv keeps shutting off and going back on by itself
Faulty parts on PS board , bad press for Samsung
When checking the capacitors, If they are slightly rounded on the top where the X is, the cap is defective.
Because the Samsung LNS4051D would not turn on and the power
LED would blink 4 times and the relay would click and this
would repeat again and again. I replaced power supply board
parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors,
three had their tops bulged up slightly that I missed on
initial visual inspection. After seeing the reports of
problems with these caps on
http://www.fixya.com/support/t1336881-will_not_turn_or_off ,
I replaced them with Radio Shack part 272-1032, 1000 uf, 35v.
They are slightly bigger, but fit OK. TV is working fine now.
Cost was 4 x $1.59 = $6.36 plus the time. I saved between
$100 to 300 in the process of either replacing the board or
getting the unit serviced. If you are not comfortable
replacing components which means using a soldering iron, you
can replace the power circuit board, available from
www.Samsung.PartStore.com.
Some UTube showing the problem and fix
http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related
http://www.youtube.com/watch?v=Mm51C_RDIZE&feature=related
http://www.youtube.com/watch?v=BNHHrgX_6cs&NR=1
Posted on May 27, 2010
  • 38 Answers
SOURCE: toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Posted on Mar 05, 2011
Apparently there was a bad lightning storm last night that knocked out our power. Bad thing is, when the power came back on our cable box won't turn on and neither will our tv. The tv power button just...
please call a specialist in that for assistance.
As of now and future: Follow what everyone says: "Turn off the modem and TV during a lightning storm".
Jul 25, 2013 | Televison & Video
Panasonic Viera TH-42PV500A blinks 11 times after turning off by itself
go to Menu, AND restore to the factory default. Read your owner manual or download from www.fitness.manualsonline.com +
www.retrevo.com
If the problem persist, you have problem with the power supply circuit. You must go to the repair shop TV for fix it.
God bless you
Jul 20, 2013 | Televison & Video
My mini 10v Dell won't charge the battery, and if I take out my battery to just run on power it won't turn on. The light that lights on if power is on blinks for a sec or two and shuts back of
take the battery out and hold the power button for like 15 seconds. then put battery baCK on and plug it in but do not try to power on. lets saee what goes? remember not to power on
Jan 31, 2013 | Dell Inspiron Mini 10v Netbook Computer
I shut the tv off last night and now it won't turn
If total dead (no lights on blinking etc) follow power cord into the set and find and check the main fuse--in this set it usually is a glass 5 amp fuse.
Dec 19, 2012 | RCA P52926 52" Rear Projection Television
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
