Question about Sony KP-57WS500 57" Rear Projection Television
Pink Rear Projection TV
Yes the picture on the tv is pink when it first comes on,then after about 15 to 20 mins later it is alright.What could be causing this and is it worth fixing.Thank You! JS.
  • James Sullivan Jul 14, 2014
    My tv is a Toshiba and i don't know if it has the CTRs.
    Problem Solver:
  • 4 Answers
If your TV uses CRTs to project an image on the screen, it sounds like either the red one is goofy, or the green and blue CRTs are goofy.
I had a CRT-based Sony RPTV, and had problems with one of the CRTs dying. I had an extended warranty that covered the bill, but the repair tech (who'd actually been to my house for several other issues with this TV) told me that I'd saved a ton of money having that extended warranty (or service contract if you must). He said that replacing the CRT would have been about a $500 or $600 service call.
Frankly, I'd just bag it and get a new TV. I'd look for a store that will cart your old TV away for you because you don't wanna give yourself a hernia lugging that old monster out to the curb.
Not only will the picture be significantly better and brighter, but you can also pick up a TV will all the nifty internet gizmos included.
Posted on Oct 16, 2013
SOURCE: Rear projection TV picture problem
open up the back and look at the top of the glass leans covers if they are dusty clean it
Posted on Jul 14, 2007
ctf1800
  • 4402 Answers
SOURCE: sony wega KDF-42WE6 55
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
Posted on Jan 21, 2008
  • 41 Answers
SOURCE: sony xbr-52in projection tv show double picture's
It sounds like a convergence problem. A fairly common reason for thisproblem is the convergence chips have failed. They are usually referredto as "STK" chips since the model number of these chips start with STK.I will put a link to another part of this site where someone has postedpictures and a link where to get the parts should you decide to fix ityourself. Look at Ecullier2012's posting. Jean's posted site will notfix this problem. Hope this helps you out. Let me know.
http://www.fixya.com/support/t1684874-screen_blue_green_green_red_outlines
Posted on Mar 16, 2009
  • 80 Answers
SOURCE: Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Posted on Aug 08, 2009
Slinteriors
  • 8617 Answers
SOURCE: Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Posted on Dec 21, 2009
Testimonial: "This is by far the best response I have ever gotten on any question. Clear, concise and directed me to the source I needed to fix the problem."
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
I turned on my TV and the whole screen has a pink tint
If using a box for signal disconnect it from power for a while to see if when it reboots this issue is gone or not.
Nov 28, 2012 | Samsung HLP4663W 46" Rear Projection HDTV
My mitshibitchi 1080hd has double vision with green and pink working perfect then all of a sudden
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,the tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to fix the tv convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Mar 21, 2011 | Sony KP-48S75 48" Rear Projection...
Blank Screent with flashing pink bands
hitachi bs always have bad voltage regulator ic's like an STR6301,Need to replace
May 05, 2010 | Hitachi 51F500 51" Rear Projection...
I just replaced the bulb in my Sony 55'' Grand Wega. the picture looked fantastic the first day. turned on the TV the next day and everything that should have a ''white color'' looked pink. the blues...
Please adjust TINT control of Video Settings in Menu that will adjust color tone of TV. I do not think this problem is related with Lamp because TV screen does not have any color blobs or spots.
Above solution is for Sony KDF-55WF655 model TV, if your model number is different, let me know.
Thanks.
Nov 29, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Panasonic projection lcd pt-44lcx65 pink wavy lines
The problem is the computer in the TV is set to hold data for 2500 "On/Offs" Once you turn the TV on and off 2500 times, the dots start to appear as the computer cannot store anymore date. Call Panasonic, they will send a tech to your house for free and reset the computer and update it at the same time from 2500 to 1 million on/offs so it wont happen again. It takes maybe 10 mins to complete.
Hope this helps.
Mar 25, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Pink and greenish lines creating a double picture
with your remote go to your menu and find convergence. Follow the instructions to auto set convergence. if that don't fix it the problem convergence panel if bad.
Mar 15, 2009 | Philips 55PW9363 55" Rear Projection...
Pink hue
Remove speaker grill, manually adjust red drive untill red is normal.
Sep 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pink in picture and green ghosting on live program with live people in picture
yes sounds like all 3 tubes are going bad. they are prolly not available anymore. try to adjust the settings in the menu. adjust PICTURE as low as possible and boost the BRIGHTNESS this might help but fixing this tv would not be cost effective.
Oct 17, 2007 | Sony KP-48S75 48" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
