Question about HP Computers & Internet
Group client service failed logon access denied
The group policy client service failed the Logon. access is denied
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Re install the windows
Posted on May 23, 2014
4 Suggested Answers
  • 13 Answers
SOURCE: cannot log on to laptop
What is your OS ?? If it is windows xp and you didnt setup admin password when your sysrem was instaled you can try restart your laptop, When will start rebooting wait till you see second boot screen and start pressing F8 when you will see emergancy menu click to save mode, Log on as Admin (not your name) and when system willl started go to: control panel,user accounts,logon as admin,go to your profile(account with your name) and press remove password. then restart your computer. Your password will be gone.
Posted on Feb 07, 2009
  • 3278 Answers
SOURCE: Each time I type in
Hello.
Boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
Hope this helps.
Posted on Jul 14, 2011
jagojay
  • 200 Answers
SOURCE: INSPIRON 1545 WON'T LOG IN MESSGE READS 'THE GROUP POLICY CLIENT SERVICE FAILED THE LOG ON ACCESS IS DENIED' RUNNING WINDOWS 7 HOME PREMIUM
Are you able to get to the desktop in safe mode?
Repeatedly press F8 on startup and choose to boot to safe mode in the options window.
Posted on Mar 28, 2012
I cant logon to my user, the message is The Group Policy Client Service failed the logon. Access is denied
I think that it is possible because of the client server isn't running. Try contacting your administrator.
Jul 23, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Tip
Fix Windows 7 Error ?Windows is Not Genuine? Error code 0×80070005
Those users running genuine version of Windows 7 provided with their hardware platform reported that immediately after log on they were presented with following error message. “Windows is not genuine. Your computer might not be running a counterfeit copy of Windows. 0×80070005.”
Some other symptoms of associated with this issue are,
The computer desktop background is black, and you receive the following error message on the bottom right corner of the screen:
“This copy of Windows is not genuine”
You receive the following error message when you view the System Properties: (Control Panel / System and Security / System)
“You must activate today. Activate Windows now”
If you try to use slmgr.vbs /dlv to view the licensing status, you receive the following message:
Error: 0×80070005 Access denied: the requested action requires elevated privileges
Microsoft is fully aware of this issue and provided following explanation for the issue,
There is a lack of permissions in the registry key HKU\S-1-5-20. The Network Service account must have full control and read permissions over that registry key.
This situation may be the result of applying a Plug and Play Group Policy object (GPO).
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B).
Method A: Disable the Plug and Play Policy
1. Determine the source of the policy . To do this, follow these steps:
a. On the client experiencing the Activation error, run the Resultant Set of Policy wizard by clicking Start, Run and entering rsop.msc as the command.
b. Visit the following location:
Computer Configuration / Policies / Windows Settings /Security Settings / System Services /
If the Plug and Play service is configured through a Group Policy setting, you see it here with settings other than Not Defined. Additionally, you can see which Group Policy is applying this setting.
2. Disable the Group Policy settings and force the Group Policy to be reapplied.
a. Edit the Group Policy that is identified in Step 1 and change the setting to “Not Defined.” Or, follow the section below to add the required permissions for the Network Service account.
b. Force the Group Policy setting to reapply: gpupdate /force (a restart of the client is sometimes required)
Method B: Edit the permissions of the Group Policy:
1. Open the Group Policy that is identified in Method A, Step 1 above, and open the corresponding Group Policy setting.
2. Click the Edit Security button, and then click the Advanced button.
3. In the Advanced Security Settings for Plug and Play window click Add and then add the SERVICE account. Then, click OK
4. Select the following permissions in the Allow section and then click OK:
Query template, Query status, Enumerate dependents, Interrogate, User-defined control, Read permissions
Note: The Previous rights are the minimum required permissions.
5. Run gpupdate /force after you apply the previous permissions to the Group Policy setting.
6. Verify that the appropriate permissions are applied with the following command:
sc sdshow plugplay
The following are the rights applied to the Plug and Play service in SDDL:
D:(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;SY)
(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;BA)
(A;;CCLCSWLOCRRC;;;IU)
(A;;CCLCSWLOCRRC;;;SU)
S:(AU;FA;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;WD)
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to “SU” (SDDL_SERVICE – Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
SU: Service Logon User
Note: If there are no GPO’s in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
1. On the computer that is out of tolerance, start Registry Editor.
2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions…
3. If the NETWORK SERVICE is not present, click Add…
4. In Enter the object names to select type Network Service and then click Check Names and OK.
5. Select the NETWORK SERVICE and Grant Full Control and Read permissions.
6. Restart the computer.
7. After the restart, the system may require activation. Complete the activation.
on Jul 15, 2010 | Computers & Internet
Tip
Method A: Disable the Plug and Play Policy 1. Determine the source of the policy . To do this, follow these steps:
Method B: Edit the permissions of the Group Policy: 1. Open the Group Policy that is identified in Method A, Step 1 above, and open the corresponding Group Policy setting.
sc sdshow plugplay
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
on May 19, 2010 | Computers & Internet
Mar 28, 2012 | Dell Inspiron 1545
Each time I type in my password it tells me The grop Policy Client service failed the logon. Access is denied.
Hello.
Hope this helps.
Jul 14, 2011 | Dell Inspiron 1521 Notebook
I have genuine windows 7 but computer says that it is not genuine
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B). Method A: Disable the Plug and Play Policy
1. Determine the source of the policy. To do this, follow these steps:
a. Edit the Group Policy that is identified in Step 1 and change the setting to "Not Defined." Or, follow the section below to add the required permissions for the Network Service account.
Query template
Query status
Interrogate
Read permissions
sc sdshow plugplay
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to "SU" (SDDL_SERVICE - Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
Note: If there are no GPO's in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
  2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions...
  3. If the NETWORK SERVICE is not present, click Add...
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 13, 2011 | Microsoft Windows 7 Ultimate 32 & 64 BIT
Hp laptop unable to start
Hi if you flip your laptop may see that there is a squared cover with two screws remove the two screws and the cover at this time you will see the memory card it might be two or one remove the memory card make sure not touch the connector side of the memory. if have pencil eraiser clean the memory card connectors and clean it again with cotton bud with alcohol let dry. Reinstall it back and turn on you laptop. if this will not work your hard driver is the problem. Hope this info will help you solve the problem.
HH
Aug 20, 2009 | HP Pavilion dv6000z Notebook
Event 534 - The user has not been granted the requested logon typ
I am sorry, but I can only suggest that you contact WTS and Citrix, I do not have the access needed to be able to assist you with login failures.
Ryan Frame
Creative Energy Associates Technical Center
Aug 13, 2009 | Microsoft Windows XP Professional With...
Cannot log on to laptop
Dec 27, 2008 | Computers & Internet
Logging on to server
You need to go into administrative tools and look for group policy.
In the local computer policy
Windows Settings > security settings > Local policies > user rights assignment. In the right hand pane find the policy for "Allow log on locally" Set the user accounts for those users which are allowed to log on interactively on the server. Be careful you dont lock the administrator account out.
Use in conjunction with the "Deny logon locally policy" if you need to.
Hope this helps
Mar 22, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
