Marantz 6300 turntable - no sound.
I have a Technics SL1300 running through Sony integrated amp with no problems. I unplug the SL1300 from phono input and plug in Marantz 6300 - no sound. Change headshells - both headshells work on the Technics, neither headshell gives audio on the Marantz.
SOURCE: Headshell for Denon DP-45F Turntable
The PCL-30 does not look like a standard headshell. I doubt the above answer is correct.
Posted on Sep 06, 2008
SOURCE: Dual 1009. No audio from the stylus & humming.
I can help with this issue. To keep the platter spinning in manual mode, you have to cue the tonearm up and move it so it is over the record. Then flip the lever to manual. It should stay on in this position. This is a feature and not a bug.
Regarding the audio / humming problem. The Duals had what was known as a muting circuit that engages as the turntable is cycling between rest and play. The fact that you are getting no sound may be an indication that the muting circuit is still engaged. Here are a few things you can try:
1. If the unit was recently shipped, you may need to reset the mechanical function of the turntable. You can do this by locking down the tonearm to the tonearm rest, turning on the power and then flipping the lever for a full automatic cycle. The tonearm will stay fixed to the rest, but the remainder of the mechanical system underneath will be reset to proper positioning (this is detailed in the Dual manual). Of course, this assumes that everthing was OK prior to shipping.
2. Make sure your cartridge is properly mounted with a good stylus, check your tonearm wires (both in the headshell and underneath the turntable and finally, see if you can get underneath the turntable while you run an automatic cycle to see what is going on.
Lastly, if you can't get it going, Check out Bill at www.fixmydual.com He worked on my 1019 and knows them inside and out.
Good Luck,
Jerry
Posted on Apr 26, 2009
  • 4234 Answers
SOURCE: Tonearm Weight, Good Replacement Stylus, Gain level
Most good turntables will track with weights between 1.25 and 1.5 grams. Any more than that and you are putting alot of pressure on the needle. Experiment a bit and make sure that the needle tracks well and that the sound is good. The less weight you use, the longer the needle will last and the less wear on the record.
Dan
Posted on Aug 11, 2009
bob_computer
  • 3153 Answers
SOURCE: i PURCHASED A LIKE NEW TECHNICS SL BD27 TURNTABLE.
Yes you need a pre amp
It would also be the same if you connected it to a computer to record an LP to CD. Mine is a little different and has one already built in that I can switch in and out of line.
Try spend a little more if you can as many pre amps can introduce noise.
You may also want to check that the turntable is properly grounded to prevent noise too
Posted on Oct 02, 2009
Testimonial: "VERY FAST RESPONSE. THANKS"
dunnbiker
  • 8546 Answers
SOURCE: I have a DENON DP-47F
At least 7 of them on eBay with cartridges. Search "DENON DP-47F headshell" and check 'inlcude description' box.
http://cgi.ebay.com/NEW-TURNTABLE-HEADSHELL-CARTRIDGE-DIAMOND-NEEDLE-/350438023145?pt=LH_DefaultDomain_0&hash=item5197bbdfe9
http://cgi.ebay.com/NEW-TURNTABLE-HEADSHELL-CARTRIDGE-DIAMOND-NEEDLE-/350438814767?pt=LH_DefaultDomain_0&hash=item5197c7f42f
Posted on Apr 26, 2011
Technics SL1300 replacement stylus
Your amp must have a dedicated phono socket, otherwise you will need a magnetic cartridge pre-amp to hear it playing, via an aux socket on your amp.
The cartridge will have a make and number on it, put that into Google and it will find the stylus. If your cartridge is old or faulty. You can replace it with any other make you want. Most will fit the deck. With cartridges the more expensive it is the better the sound, generally unless it's just a well known brand or something just to be flashy!
Nov 26, 2016 | Technics Audio Players & Recorders
Kenwood turntable no sound?
Are you using a magnetic "PHONO" input on your amp/receiver, or just a line/aux input? The 'good' turntables from the 70's - 80's used magnetic catridges with a very low level output - you will need a phono preamp in order to hear the turntable. Only phonos (Crosly) that use ceramic catridges generate enough voltage without a preamp. Good luck and let me know if that answered your question.
Aug 10, 2014 | Technics SL-1210 Turntable
Cannot hook up sound to surround sound , everything else works, cd player, radio, tapedeck. just the turntable does not work. any suggestions? deb
Hi, you need to connect the turntable to your amp via a phono input connection. If no phono input available then a pre amp needs to be used between turntable and amp to up the signal. Cheers John. Styluscity@gmail.com
Sep 28, 2011 | Technics SL-1200MK2 Turntable
I recently bought this turntable used. I am trying to connect it to a Sony receiver with a phono input, but no sound comes out when connected. Does this turntable require a pre-amp or something?
If the unspecified Sony has a "PHONO" input you should be good to go. What model?
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify and frequency-correct the tiny current produced by a Phono cartridge. Look up RIAA equalization.
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
http://shop.ebay.com/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=phono+preamp&_sacat=See-All-Categories
Jul 27, 2011 | Panasonic Technics SL-1210MK2 Turntable
We want to connect a SL-B5 to a sourround system and the sound its not coming out what should we do?
is your surround system has a phono input? because most of the turntable can only work with the unit that has a phono input, phono input has a a built-in pre-amp. so if you're only hooking your turntable to an ordinary input then this might be the case, you won't hear any sound or sometimes weak sound.
Jun 13, 2010 | Technics SL-1210 Turntable
SL-BD22 SETUP
go to RADIO SHACK and get a pre amplifier module (hope its still available) , that will do the trick , AJ
May 20, 2009 | Technics SL-BD22 Turntable
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
Volume
Please let me know how your turntable is connected to the music system. I mean, to which input ? (Tape/Aux/Phono/VCR/CD) ?
Aug 24, 2008 | Technics SL-1200MK2 Turntable
Not a good sound
you can't...the technics need to be pluged into phono..because the signal has to be amplified for it to play...phono channels on amps and dj mixers have an amp built in....
Apr 06, 2008 | Technics SL-1200MK2 Turntable
77 people viewed this question
 Grubhead
Grubhead
