Question about Hardware & Accessories
How do you rewire a light fixture? - Hardware & Accessories
  • 5,089 Answers
Add a photo or video so expert can see what type light fixture.
Posted on Jul 20, 2013
Can I replace the VEB82122 ballast on my hunter fan with a "regular" light kit?
Use an 8 inch Circline T9 daylight LED and directly relamp fluorescent FC8T9 bulb without rewiring
Feb 18, 2017 | Hunter Dryers
Rewire a three-way switch that was wired knob and tube?
I can help u with this but will need to b able to walk u thru it,
Feb 26, 2015 | Electrical Supplies
Rewire lamp
It depends on the problem. Common problems such as bad sockets can be repaired by a handyman. Lamp sockets, switches and heat resistant fixture wire are readily available from big box stores, local hardware stores, etc. If the problem is related to the house wiring, you need to contact an electician.
Mar 12, 2014 | Hunter Dryers
Rewire a light box with four wires
I can help... but cannot see your drawing.
Let's get started:
1) By code, the microwave? should be on dedicated circuit
2) You have 4 cables that enter the box.
3) Only 1 cable will be Hot and Neutral from breaker box. You must identify this cable first.
Here is drawing:
http://waterheatertimer.org/images/Pantry-door-switch-1000.jpg
Apr 06, 2013 | Gardner Bender #GSW-SK Door Switch
Need to know how to fix light,only a flicker of light shows
Probably the photosensor is wired wrong? Or is bad.
Which light fixture do you have?
Is the photosensor integral to the light fixture?
What wiring did you change?
What was the matter with the previous wiring?
What else is on same circuit?
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
Aug 28, 2012 | Hardware & Accessories
Why does dusk to dawn light have only a dim light
Add a comment to start dialog.
We have 48" lithonia flouresent
even if there is power at the sockets, ballast may not have power to fire off the lamps, how old is this fixture, and you need to replace the ballast same as in fixture, if you replace ballast make diagram of wiring so you can rewire it like it was wired from store.
Aug 21, 2011 | Lithonia Lighting White Finish 2 12" High...
I open the door to the refeg and it smells like wires are burning. I unplugged it. The lighting fixture is loose. The plastic around the light is defected.
A loose connecction of the bulb holder can heat up and burn the holder plastic material -- as a faulty connection will spark and heat up. The best option is to remove the holder , rewire and replace the unit.
Jul 02, 2011 | Microwave Ovens
To replace a ceiling light with another, can one just turn off all the power coming to the house, and rewire the new light, matching the wires?? Few electricians want to come to the house for such a...
Turning off the circuit breaker to the circuit is sufficient, but if you feel better turning off the main, do it. Just turn the light ON then turn off one (single pole) circuit breaker at a time until the light goes out. Then, like you said, just match the wires.
Jun 30, 2011 | Universal Lighting and Decor White 11"...
Hardware & Accessories Logo
22 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
