Sumsung WA13V9 drain water all the time
Why my sumsung WA13V9 drain water all the time?
I have a Samsung WA13V9 top loading washing machine, the water is not flowing into the machine when turn on. Inlet hoses and filters are clear.
It's possible to be the door switch fault.
Teoretically if the door is not close, the water isn't flowing into machine.
Jun 03, 2017 | Samsung Washing Machines
I have a Samsung WA13V9 top loader washing machine the water is not stopping when the cycle starts I have to turn the water inlet tap off for it to stop.
If the water keeps running all the time whether the machine is on or off, the water solenoid valve in the machine has failed. If it only fills when the machine is on, it is likely to be something with the water level control. The pressure hose could be blocked or disconnected or the pressure switch or water level sensor has failed. I'm not fully conversant with the Samsung but the same principals apply.
Mar 20, 2017 | Samsung Washing Machines
My Samsung WA13V9 washing machine doesn't drain or spin, but I think the pump motor is working. where can the problem be?
Check that the wiring inside is not damaged, if ok check that the start timer is not stack, if ok check that the drain pump is not blocked eg a coin stuck in it, if ok check that the start capacitor for the main spin motor is ok if not replace with same rating, if ok check if main spin motor is ok eg using continuty tester to check windigs or simply smell it and if burnt expect a pungent smell from it.
Aug 03, 2015 | Samsung Washing Machines
I want samsung wa13v9 wiring manual
www.samsung.com/us/support
You may have to write to them and ask. They are the ONLY ones who created it.
Jul 03, 2014 | Electrical Supplies
How do l fix WA13V9 IE error
What's the model number this will help me with the type of machineyour working on.
Jun 08, 2014 | Samsung Washing Machines
Sumsung top loader will not drain
What is the model number?
Oct 14, 2012 | Washing Machines
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
