Pdl common hp laserjet 5200 pdl_common how to solve the problem
2 Suggested Answers
  • 236 Answers
SOURCE: My printer HP LASER JET 5200 DTN shows "Ready" on the display but it doesn't print, how can I fix this?
First thing you need to do is establish whether the print engine itself is at fault, or not.
From the relevant printer front panel menu, invoke printing of one or more of the available reports (configuration, font list, etc.); do these print?
If the reports print OK, try to send some plain text to the device.
On a Windows system, you could do this by using the DOS copy command in conjunction with an appropruate net use command to redirect LPT1: to the (USB) port associated with the relevant Windows printer instance.
Posted on Jun 02, 2015
Testimonial: "Thanks about youranswer ;but let's say that the printer itfsef is at fault ( i access to the menu to print report ;;;;;i always get systeme procesing ;;;;"
How can i solve error code 4900FF HP 5200 ?
This is occur due to few things, first you have to check your document is not corrupt, if it is ok then you need to restart your printer once.
Jan 25, 2017 | HP LaserJet 5200 Printer
Error 49.4c18 hp laserjet 5200
hp 5200 printer error messages 49.4c18
Apr 15, 2013 | HP LaserJet 5200 Printer
Hp laserjet 5200 grinding noise from left side
front, rear ? I'd say fuser assembly gears or drum on toner cartridge; check the gear teeth on the toner cartridge's drum.
Dec 20, 2012 | HP LaserJet 5200 Printer
49.00ff error in hp laserjet 5200
Does the same thing happen if the printer is disconnected from the network (I'm assuming that you are using an Ethernet connection) before you power-off then power-on again?
If it does, then there is a problem with the printer itself.
If not, then it may perhaps be invoked by some system sending a 'rogue' job (not necessarily a conventional print job) to the device.
Look at HP support site for the latest firmware update to your model. Regards, Mike
Sep 08, 2012 | HP LaserJet 5200 Printer
HP Laserjet 5200 top bin full
Hi, Remove all the papers from out put bin & check if not solved remove both side and top covers absorve right side of the out put bin flag sensor clean it with high pressure air or clean with dry cloth gently. Best of luck...Vinay
Apr 18, 2011 | HP LaserJet 5200 Printer
HP laserjet 5200 printer taking too much time to print a page..
HP 5200 prints 35 pages/minute, however, system configuration and software reduces print speed. So, If there are no changes in those parameters, you're document is too complex to print quickly.
Try to send a test or a text page to calculate the difference.
Also bare in mind that first page takes longer to print due to printer heat-up procedure.
Nov 09, 2010 | HP LaserJet 5200 Printer
Paper jam hp laserjet 5200
All printers after sometime the rollers start grapping more than one sheet that result in paper jam or dirt building up inside…make sure you open the printer and clean it good and see if you can locate any small papers that usually stuck inside…let me know
Please do not forget to rate the service for the site to continue helping everyone and improve on it.
Sep 16, 2009 | HP LaserJet 5200 Printer
HP LaserJet 5200 PCL 6
check where are you unzip file, and start setup from desination folder
Jun 16, 2009 | HP LaserJet 5200 Printer
jasbo
jasbo
