Question about Magic Paris By Yves Saint Laurent for Women
Watch loses time after getting it wet when i wear it only
Was working fine and forgot to take it off while washing dishes noticed later that it had stopped and finally it started working again but when i wear it it gets several hrs behind
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 85 Answers
Put in a cup of rice for a few days needs to dry out, hope this helps
Posted on Feb 25, 2014
Hotpoint wf320p washing machine leak
pull the plug
check the pipes from the soap dish to the tub
Feb 09, 2014 | Washing Machines
First I noticed that the clothes after washing them were still a little too wet---then a month later, a loud noise ensued. no leaking no smoke and still wet clothes, also no shaking.
Sounds as if the belt may have a flat spot in it. They run about 24 dollars online. Take
a look at it by unplugging it and having someone hold the machine back at an angle.
There should be an obvious area of excessive wear somewhere on the belt.
Also check the idler pulley (wheel) for excessive play or binding. Hope this helps.
Mar 10, 2011 | Speed Queen AWS75NW Top Load Washer
High oitch noise during wash
As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
May 04, 2010 | Frigidaire Professional Series 24 in....
Watch stops or loses time every time i wear it.
normally automatic watch need to wear at least 8hrs in a day ,then it works for next 30hrs.if it stops or loosing time, it indicates that needs service with lubrication .
Feb 23, 2010 | Navy Seal Luminox Dive Watch
I have a Luminox Navy Seal Watch. It has worked fine for about 6 or 7 years. I noticed that the minute hand seems to stick and then release about 4 seconds at a time. Is this something that needs to be...
Obviously you never noticed this before. Do nothing, as there is nothing to fix. This is normal behaviour sooner or later noticeable on all quartz watches.
Rate me, plz.
Jan 11, 2010 | Watches
Brand New Bosch Stopped Working On First Use
need to make sure no breakers have tripped if not then replace operating thermostat. if it is only a few days old you should be able to get the dealer to cover service call and labor
Jun 21, 2009 | Bosch Evolution 500 SHE45M05UC Stainless...
No question that it is a warranty problem, you shouldn't consider doing anything on the machine yourself at this point.
After the warranty is dead and it fails, c'mon back and you will likely find someone to help. It is good though, that we are forewarned about Bosch-
Jun 21, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Dishes come ot just like I put them in
Check that both spray bars are turning. They can both be easily removed.
Once removed, make sure they are not clogged with stuff to prevent them from turning.
I assume you can hear water spraying around inside when it's washing, and that the dishes do get wet, and water does get hot.
Soap dispenser requires water hitting on it to open.
Jan 28, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 | Watches
Dishwasher not drying
I've recently had the same problem. My theory (to be confirmed) is that the heating element is not working properly (in my case not at all). This may be the element itself or the control for the element. This, I think, may account for the machine running for so long - it is waiting for the water to reach operating temp before timing the wash cycle. This also explains why the dishes do not dry. I aim to investigate this theory over the weekend !!
Oct 17, 2006 | Zanussi 32 in. DE6755 Dishwasher
Magic Paris By Yves Saint Laurent for Women Logo
102 people viewed this question
Top Magic Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Magic Health and Beauty Expert? Answer questions, earn points and help others
