Question about Makita Hammering
Lights stay when off - Makita Hammering
Kawasaki Voyager xii 's cruise set light stays on,the bat light stays on and the neutral light will not light
the computer in you vehicle tell them when to come on and off. you might wanna get it tested.
Dec 28, 2012 | Cars & Trucks
Ford e250 brake lights stay on
If the lights only stay on when key is in ignition, your central brake lights (or one of the lights) are out. The other lights stay on as a warning that the centrals(or other brake light/s) are needing replaced.
Feb 07, 2012 | 2003 Ford E250
I have a 1999 dodge caravan. Passenger sign turn signal flashes for a short period & goes solid. Reverse light & brake light work just fine. Multifunction switch, light sockets, light assembly...
Sounds like the relay is burning out. When the lights stop flashing does the indicator on the dash light up and stay on and/or does the exterior lights light up and stay on? If the indicator light is staying on then you have a wiring problem to the lights or you have the wrong bulb/ bulbs. If the exterior lights stay on it is a bad relay or power to the relay.
Oct 31, 2010 | 1999 Dodge Caravan
Abs light stays on.
that is the auto check system, if when you start the car the abs light stays on then you have a problem,
Jul 04, 2010 | 1996 Cadillac DeVille
Do the headlights stay on always even during daylight driving on a 2008 Saturn Vue
YEP ALL TODAY CARS COME FROM THE FACTORY WITH DAY TIME RUNNING LIGHTS WHICH STAY ON WHILE YOU DRIVING.IF LIGHTS STAY ON WITH ENGINE OFF YOU HAVE A FAULTY DRL RELAY OR DAY TIME RUNNING LIGHTS RELAY.YOU COULD HAVE TURN ON HEAD LIGHTS MANUALLY FROM THE SWITCH.WHICH WILL CAUSE HEAD LIGHTS TO STAY ON.
Apr 28, 2010 | 2008 Saturn VUE
91 honda accord brake lights stay on replaced
are you sure you the adjustment to it is correct the button in the end of the switch has to be fully depressed to deactivate the circuit
Jan 19, 2010 | 1991 Honda Accord
Hammering Logo
Top Makita Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Makita Hammering Expert? Answer questions, earn points and help others
