Bosch maxx wfl 2061
Clothes are still soaking wet after wash. and quick wash takes 3 to 4 hours to complete.
  • 1294 Answers
SOURCE: Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage. Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
Posted on Jun 11, 2007
  • 139 Answers
SOURCE: Bosch Maxx WFL 2260
Hey check to see if you can move the drum by hand,, if you cant the the bearings on the drum have gone and it is seized ..
If you can turn it by hand then most likely it is the carbon brushes on the motor..
hope this helps
any questions dont hesitate to contact me im here to help....
Posted on Jan 17, 2008
  • 1462 Answers
SOURCE: Bosch Maxx WFL 2061 motor starts running and then stops
i nassume you mean that motor accerates to an uncontrolled speed.
check the motor tacho - mounted at the opposite end to the pulley. tacho consists of a circular magnet surrounded by a pickup. magnet may have unscrewed itself from the motor shaft
Posted on Nov 29, 2008
  • 228 Answers
SOURCE: The water does not cutoff during rinse cycles
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Posted on Feb 17, 2010
tony2155
  • 64 Answers
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Posted on Mar 28, 2010
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
The drum stopped turnig and there seewms to be no life in the motor on our BOSCH Maxx WFL 2060 does any one have any idears. Thanks
you need to test the motor to see if voltage is getting to it.. if yes change brushes or motor complete...01179512835
Dec 30, 2009 | Bosch Axxis WFL 2060 Front Load Washer
We have a WFL 2090 UC Bosch Axxis Front end load washer. When we use the Power Wash option, the clothes are soaking wet when the cycle is completed. Are we supposed to use the Power Temp or Power Boost...
Are you sure that your washer spins? that your pump drains? You should not have this problem. Do you load your laundry properly (too much laundry- should not be more than 3/4 of the diameter of the drum)?
Jun 28, 2009 | Bosch Axxis WFL2090UC
Need instruction manaul for bosch wfl 2260
Programmes appear to be taking excessively long time to complete even with the quick wash button pressed - 2 hour 15 min for 30 Cotton wash cycle. Is this right or is there a fault? 30 Easy-care seems to be taking almost as long.
May 17, 2009 | Bosch Washing Machines
Bosch Classixx WFL 2462 Front Load Washer
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
Jan 16, 2009 | Bosch Classixx WFL 2462 Front Load Washer
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace pkurdnirund@hotmail.com , peacepattaya@gmail.com
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Jun 10, 2007 | Bosch Classixx WFL 2066 Front Load Washer
Open Questions:
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
