Question about Frigidaire GLTF2940ES Front Load Washer
"e 10" error code
I have found out that "e 10" means water supply but nothing else. I have to push start 4-5 times each load. I have good pressure at the hoses. Anyone have any advice? thanks
  • 1 more comment
  • MARLBORONJ Nov 06, 2007
    I HAVE THE SAME PROBLEM "E 10"; HOWEVER, MY CODE WATER IS THERE AND WITH GOOD PRESSURE. I ONLY GET THIS ERROR CODE ON THE FIRST CYCLE OF THE COLD/HOT WATER WASH. HOT WATER ENTERS BUT COLD DOESN'T. PLEASE HELP...
  • hoogabooga Nov 10, 2007
    I found my problem. I took the cold water haose of and there were two tiny pieces of trash against the screen that goes into the washer. Cleaned it out and no more problems.
  • Anonymous Apr 03, 2008
    I am having the same problem. Error code 10 comes on at the beginning of the cycle, Within the first few minutes , i just rehit the start button and it goes through the whole cycle.
    I have my set for about 6 months
E10 usually means hot and cold water lines are reversed or your cold water supply is lacking ie: low pressure, clogged etc. Hope this helps
Posted on Sep 22, 2007
SOURCE:
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
What does "LF' mean with lights blinking?
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
(Tip Courtesy JSRock)
Thanks for using FixYa
Feb 10, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Oasis top load washer will not spin on the last cycle. Error Code LF. Cant find my manual to see wha this means
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 17, 2010 | Kenmore Washing Machines
I have a kenmore elite top loading washing machine model number 110.2706, 2707, it keeps giving us the message LF, what does this mean?
Apr 25, 2010 | Kenmore 24032\24036 Top Load Washer
Lf code on washer.checked hoses and valve both ok unit will run after opening the lid and closing lid and pressing start again. takes 10/15 minutes for a load to start
LF means that it is taking too long to fill. (If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.)
Supply hoses could be kinked or clogged(some have screens in the end).
This could be a supply water pressure/flow problem. Make sure you have good water flow though the hoses to the machine. (Take off and try running into a bucket)
The water fill valve may be failing to open all the way or it could be clogged.
I hope this helps.
Mar 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
What does the code LF mean?
Jul 28, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Stops before spin with error code of LF
Apr 20, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Duet Error code F 32
Plug off the wall. Open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass thru, it shd not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there shd be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Dont forget to refit the main exit hose at the position you found it. All you guys are going to rate me....................
May 01, 2008 | Whirlpool WFW9400S
Frigidaire GLTF2940ES Front Load Washer Logo
547 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
