Kelvinator problem how do I fix an E4 error on a kelvinator inverter split system air conditioner model # KSV35CRB
3 Suggested Answers
  • 121 Answers
SOURCE: kelvinator split system a/cond
An air handler comes with a low, medium, and high speed wire taps and can only be set through these taps.
Posted on Oct 16, 2008
caroldon
  • 17129 Answers
SOURCE: we are installing a kelvinator
If the installation is not done by an experienced AC technican who does not know the size of the piping , I would not recommend you to proceed further as you might end up with a faulty installation. Please get this work done by a person who knows the subject or else the pipe connections and fittings may not be good enough to prevent leak of the gas thereby reducing yourr efficiency and reduce cooling.
There is more to this than just fitting the pipes and I advice you follow them wisely.
Posted on Nov 03, 2010
Kelvinator split system heater off every 5 minutes for about 4 minutes then it comes back on and does this constantly .
Here is the free help link.
Air Conditioner Repair Help
Here is the PDF. It does not list the problem you identify but lists the contact information for Kelvinator. Bear in mind your problem could be a blockage, a bad sensor, or oddly enough, the filter needing changing. This calls for a service technician.
https://theelectricdiscounter.blob.core.windows.net/images/air-conditioner/air-conditioner/kelvinator/pictures/e_series_inverter.pdf
Jun 05, 2017 | Heating & Cooling
My kelvinator split sys turns on for about 5 min the 4 lights flash blows warm air have no manual
If the 4 lights are the indoor unit indicator lights, it is a fault code. Do some lights stay on or do all flash? What model is it? Kelvinator ( In Australia) are sourced from various OEM suppliers, different models will have different fault codes.
Mar 16, 2015 | Heating & Cooling
Hi, i have kelvinator split system in my house.but...
Sounds like a clogged drain pan. You will need to have the unit professionally cleaned.
Hope this helps I take the time to answer your question so please rate me
May 19, 2010 | GE Zoneline AZ38H12DAD Split System Air...
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
I've got an error 1 message on my Kelvinator air
Here is a Toll free number to Kelvinator. Good Luck!
Technical Support Center - U.S.A. 1 (866) 738-1641
Monday - Friday
8:00 am - 6:00 pm EST
Nov 13, 2009 | Heating & Cooling
Remot control not working for this unit
change batterys if not working contact tech support from kelvinator
Feb 26, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Kelvinator split system a/cond
Oct 16, 2008 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
