SOURCE: Samsung SF-5100P
Machine will require fuser(hot bit at rear) replaced before it will operate, take to dealer for quote or if brave and 240v happy then buy a fuser and get your tools out rip off the covers and in the back you will find fuser assy.
link to service item fuser U.S.
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=JC96%2D01621A&search%5Fmodel=SF5100
SOURCE: owners manual
Hi tedkollias40
Here is your fax machines manual
Thankyou for using FixYa, a FixYa rating would be great for tracking this down for you. Cheers :)
regards
robotek
SOURCE: samsung sf-340 user manual
Link to SF-340 User Manual:-
http://downloadcenter.samsung.com/content/UM/200609/20060925101938281_SF-340series_English.pdf
Reason you couldn't find it on Samsung website is they have it under "Multifunction Printers". ....?!! don't ask me!!
Gingan
SOURCE: How do i change my language from arabic to english
This will work for all 2630's from whatever language it is currently set at to your desired language. Press the center square button to get the menu. Scroll down until you see the small wrench - menu #4. Press the square (Select) button again. Scroll down to #9 - the icon will look like a small phone with a wrench - press select. Press select again - menu #1. Press select again - menu #1. You should be able to see English as an option. Scroll down and select again and you should be good to go. The Nokia menu sequence is: Menu, 4, 9, 1, 1. Unfortunately, this phone does not do jumps - so you must scroll down manually.
SOURCE: i mate 6150 how to change the language arabic to English
hello
today i am going to show you how to change language arbic to english. First you go on
control panel. And then you see there regional languge you can see there lot of languge you.
Now wich language do you want you then you select that's it .
