Fedders AC plug unit in it beeps has power but display wont come on so I can't turn on unit check fuse and it's good# m7x05f2a 5200btu
5 Suggested Answers
Saigua
  • 981 Answers
SOURCE: FEDDERS D CHASSIS A6D24E7A
Oh, the compressor motor's borked or overworked and overheating, or its capacitor failed short (perhaps the motor is shutting off from thermal shutdown...but you get to find out whether that's so. Be safe.) Alternately the temperature sensors have gone touchy on you. Once you gently vacuum it clean, try keeping incandecent bulbs in series with the compressor to get an idea of how loaded that thing is as it runs for those 5 minutes or so; the load might change more than you expect, just pay attention.
Hopefully you won't have to replace the compressor or motor; but it's doable if you're a certified technician with like equipment (so you can handle the refrigerant decently.) Most shops will streamline a bunch of similar jobs together to cut the waste and setup time.
Bigger conditioners are so much more efficient than little ones...syndicate the A/C?
Posted on May 30, 2008
james3751
  • 614 Answers
SOURCE: A6414w7b b wall unit gfi plug keep tripping
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Posted on Jun 13, 2009
SOURCE: I purchased and LG Model# LP1010SNR on 8-3-10 at
When you unscrew the bottom cap, there is a "rubber plug" you need to pull out. It is not on the diagram, go figure.
Posted on Aug 26, 2010
What happens on this unit is it will suddenly stop followed by a series of chimes. You can reset the unit, but it will end with the same set of chimes. My unit display had a P2 code. As mentioned above, I drained the water (small amount actually) in the shower. Note: There is a cap towards tha bottom of the unit that you will need to unscrew, then pull out the rubber plug. Fired up the unit after the water drain ... it worked fine. If they can make a GI Joe talk ... why can this unit simply say ... "Please Drain". P2 is so intuitive.
Posted on Jul 04, 2011
Air condition wont turn on
Do you have enough power to unit? Check plug for any loose wires on unit, with unit unplugged of course.
Jul 07, 2010 | Fedders A6Y18F7BCOM Air Conditioner
AC does not work
hi there,
the aircodition is tripping off due to overload protection, develop a high current on circuit there are several reason,common factor is need maintenance on evaporator and condenser,have check also on starting capacitor if busted replcae capacitor of the compressor,cloging of cappilary tube is also a factor to trp off the ac.have anice day fix my rate.thanks alot
May 14, 2010 | Maytag Chassis Built-In Air Conditioner...
My Fedders A7DH45B2A dehumidifier (about 4 yrs old) continues to trip the fuse embedded in the outlet on the wall in which it's plugged in.. What gives??
either try a different outlet to see if the G.F.C.I. is bad on this outlet or if the dehumidifier trips on another line it could be the units motor start capacitor that shorted or the compressor is bad
Apr 06, 2010 | Fedders A7DH45B2A Dehumidifier
Fedders window ac was running control lights started going on and off ac went on and off then quit power supply is fine. reset does no good
assuming that you have a reset button on the power cord and after pushing the button you dont hear a beeping sound, there's the possibility that your cord is defective. Check it with a volt metter at the end of the terminals.
Sep 23, 2009 | Fedders A6Q10F2B Q Chassis Room Air...
Console does not light up after plugging unit in
Check the power cord for rips of loosness where it enters the unit. if the power cored is fine, this will usually be the result of a power supply board failure. you should replace the power board in this case. the original board is unable to process the AC current at this time.
May 28, 2009 | Fedders A7DH45B2A Dehumidifier
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Wont change mode
changing mode all the time, beeping all the time, sounds like my wife - slap it!!
Jul 10, 2008 | Maytag Chassis Built-In Air Conditioner...
Fedders air conditioner beeps but doesn't turn on.
Unplugged unit first. Take control panel out but dont unplug wiring. Cut Firth wire out from the center on the touch pad six wire plug. Cap both ends and plug back in. now unit will run on high cool and turn it on and off by plug and unplug
Aug 15, 2007 | Fedders X Chassis A6X05F2B Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
