Question about Saeco Classico Espresso Machine
Problem with steam wand on my espresso machine
I can't get consistent steam to come out -- when I turn on the steam button and open the knob, some water comes out and then a little steam, but then it fizzles out and stops. The light is off on the steam button, which should indicate that it's hot enough (and in fact this happens even after the machine has been turned on and warmed up for a while). When I push the coffee button, I can get a steady stream of water to come out of the steam wand so I don't think it is clogged. There is water in the tank and in the hose, and I cleaned out the tip of the wand. Is there anything else I can try?
  • kbleicher May 26, 2008
    Having the same problem. Did this fix solve the problem?
Did you try to prime the wand by running water through it for 4 seconds? After you do that it should work fine.
Posted on Nov 12, 2007
Zero steam from steam wands. No pressure.
First thngs first, make sure knob is turned to 2, then make sure there is water in the boiler, then turn machine to 0, remove back panel and reset thermostat on top of back boiler, if your machine has that feature installed. Then turn machine to 2, open one of the steam wands, If within 10 minutes boiler does get hot or there is no water bubbles, from steam wand, then the pressure stat might be damaged and needs to be replaced.
Apr 14, 2011 | La Marzocco Linea Series Group 3 Espresso...
My gaggia says to ventilate and the circuit must be reloaded, what'shat?
Ventilate means to run water through the wand by opening the knob on the right for water not steam. Some machines have a button you need to push to turn the water circuit on, but others have it where you just turn the knob. If you have a drop under one of your buttons, you need to push it. If you don't, you just turn the knob.
Jan 13, 2011 | Gaggia Titanium Espresso Machine
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Our machine when turned on and menu is pressed it will show energy saving press again ventilate shows. no action
Hi
When the ventilate message is showing, push the water button is you have one then open the knob on the right with a cup under the steam wand. You should get ewater from the wand. If you don't get water from the wand check for a plug in the steam tip. If you don't have a plug in the steam tip, you may have a plugged flow meter.
Dec 18, 2009 | Gaggia Titanium Espresso Machine
Only hot water comes out of the steam wand
Hi
Sounds like you might need a new steam boiler, or you may have a fuse that is blown for the steam boiler.
Oct 06, 2009 | Saeco Vienna Digital Coffee Maker,...
Steam wand doesn't work
High pressure air using a blowgun?
Aug 24, 2009 | Saeco Starbucks Sirena Espresso Machine
Francis francis milk steamer not operating
Check the end/nozzle of the steam wand, if you open the wand and while getting nothing it is hot, then the nozzle is blocked use a paperclip to clear the hole at the end of tip. If you have done this already and still no steam then it is clogged where the steam valve connects to the boiler.
May 19, 2009 | FrancisFrancis! X1 - Stainless Steel...
The water is not getting picked up when the pump runs
sounds like you need to prime the pump manually:
Fill water tank.
Turn power on.
Open the steam knob all the way.
Press the coffee button.
Put a cup under the steam pump wand.
Wait until you see a steady flow of water and no air.
When you see the flow of water, close the steam knob.
Turn off the coffee button.
Now the machine should be ready to brew an espresso.
You might need to do this if you have not used your espresso machine for a few weeks or if it has been moved.
if that does not work contact the service center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Sep 26, 2008 | Espressione XP1 Espresso Machine
Prime it
1. Open the steam knob all the way.
2. Turn on the pump (coffee Button)
3. Turn on the power to the machine.
The machine will start to pump hot water out from the steam wand. When you get a steady flow, your machine has been primed.
For Descaler, Cleaners and Parts for your saeco machine visit
www.CeriniCoffee.com
May 28, 2008 | Saeco Classico Espresso Machine
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
Saeco Classico Espresso Machine Logo
295 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
eyecam
Marvin
Marvin
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
