Question about Casio DJ-120D Desktop Calculator, 150 Steps Check, Two Way Power, 12 Digits Extra Big LC-Display
HOW TO USE GO TO FUNCTION - Casio DJ-120D Desktop Calculator, 150 Steps Check, Two Way Power, 12 Digits Extra Big LC-Display
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
How to update older ti-84 plus
The function keys originally have twp functions: One function accessed by pressing a function key directly, the other by first pressing the 2nd key then the function key.
With the newer operating systems, there is a third function associated with the function keys F1.F2,F3 and F4, but not F5 nor F6. This third function is revealed after you press the ALPHA key.
Jul 25, 2012 | Texas Instruments TI-84 Plus Calculator
Need codes for ht3916 to chage remotes
Description=Durabrand Home Theater System (HT-3916)
Remote.name=URC-6131nwB00 PVR Remote 2K
Remote.signature=PVR0PVR0
DeviceType=Amp
DeviceIndex=3
SetupCode=1568
Protocol=00 5a
Protocol.name=NEC2
ProtocolParms=24 null null
FixedData=01 e7 e7
Function.0.name=Power
Function.0.hex=c7
Function.1.name=Mute
Function.1.hex=e7
Function.2.name=Source
Function.2.hex=d7
Function.3.name=Channels
Function.3.hex=67
Function.4.name=Reset
Function.4.hex=cf
Function.5.name=Front (-)
Function.5.hex=6f
Function.6.name=Front (+)
Function.6.hex=5f
Function.7.name=Center (-)
Function.7.hex=57
Function.8.name=Center (+)
Function.8.hex=df
Function.9.name=Rear (-)
Function.9.hex=47
Function.10.name=Rear (+)
Function.10.hex=ef
Function.11.name=Subwoofer (-)
Function.11.hex=77
Function.12.name=Subwoofer (+)
Function.12.hex=ff
Function.13.name=Master Volume Down
Function.13.hex=4f
Function.14.name=Master Volume Up
Function.14.hex=f7
Button.8=Mute'null'null
Button.3=Power'null'null
Jul 23, 2011 | Durabrand HT-3915 System
How to use antilog by casio fx-82es
The inverse of the log function is the function 10^
antilogarithm of (x)=10^(x)
The function shares the same physical key as the [LOG] function. To access it you press [SHIFT][LOG].
The antilogarithm of the natural log [LN] is the exponential function [e^x]. It shares the same physical key with the [LN] function. To access it press [SHIFT][LN]
Aug 29, 2010 | Casio FX-300MS Calculator
What is the function of 1st,2nd,3rd,4th,5th gear?
the function of the gears are to transfer and convert energy created by the engine into momentum
Feb 12, 2010 | 2003 Toyota Corolla
R6025
The R6025 Runtime Error happen when an application indirectly calls on a pure virtual member function from an invalid Microsoft Visual C++ run time library.
Nov 27, 2009 | Computers & Internet
Multimedia keyboard on function keys. Functions work with a key "Function" How to change "Multimedia keys first" on "Function keys first" ???
You can change the settings by going to BIOS. To go to BIOS, restart the system and as soon as you restart, start tapping the <F2> key located on the keyboard. This will take you to BIOS.
You can use the Function Key Behavior setting in the System Setup (BIOS) utility to configure the media control keys. The options in the Function Key Behaviour setting are:
Multimedia Key First - This is the default option. Press any multimedia key directly. For function key, press <Fn> + the required function key.
Function Key First - Press any function key directly. For multimedia key, press <Fn> + the required multimedia key.
Nov 01, 2009 | Dell Inspiron 1545 Notebook
FUNCTION KEYS ON DELL INSPIRON 8000 DON'T WORK AFTER INSTALLING W
There is no driver required to use the function keys. You just need to use the function (fn) like a shift key. Hold the function (fn) key and then press the according function key.
Mar 20, 2009 | Dell Inspiron 8000 Notebook
Plz answer, thanks!!
Click the Office Button in the upper left corner. Click "Save As"
Click "Tools" and select "General Options"
function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); } function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); }
There you can set a password to open the file or a password to modify the file.
function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); } function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); } function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); }
Jun 25, 2008 | Microsoft Office Professional 2007 Full...
Casio DJ-120D Desktop Calculator, 150 Steps Check, Two Way Power, 12 Digits Extra Big LC-Display Logo
132 people viewed this question
Top Casio Renewable Energy Experts
Kelly C
Kelly C
Level 1 Expert
Brian Lee
Marco De La Fuente...
Are you a Casio Renewable Energy Expert? Answer questions, earn points and help others
