Related Tags:
This problem should be removed because:
Problem with GE Hotpoint Top-Freezer Refrigerator
how to replace the freon in a hotpoint refrigerator
HotpointIs it hard to replace some of the freon in a hotpoint frige? We had a huge power surge and the frige smelt of freon after I yanked the plug. But after I pluged it back in it is now running fine and getting cold. The freezer (on top)is even freezing again but I have it past the middle setting so I know all it need's is some of the freon replaced. If I get a kit from a parts supply place is it hard to do? I dont have the money to pay someone to do it for me and I dont have the money to buy a new one. Even a used one is $100.00 and it would be my luck it would break down as soon as the 30 day warenty is over.
Solutions (2)
Best Solution
Well if you get another one my advice is to stay away form G.E. which hotpoint is G.E. ... Also sxs's are having quit a lot of problems.. seemes like thats all I'm working on anymore... More G.E.'s than anything else.. Good luck
The only time u need to add freon is IF you have a leak...
I dont see anyway a power surge could cause loss of freon. Not sure what u smelled but I dont think it was freon.
I wouldnt mess with opening you Refrigersnt system ...
If you do need freon... means u have a leak.. depending on how bad the leak is ..This will be how long u got before you have to add again.. No guarantee how long it would last 2 days, a week, a month???
Check to see if u have any frost build up on the back panel in the freezer,
check your condenser coils make sure no dust blockage, make sure fan in back by compressior and freezer fan is blowing... make sure u havnt turned your freezer control up cutting cooling to your refrigerator side. should be about half way
ps all fans should be blowing when refrigerator is running
Well I sure am glad every thing worked out for you .. good luck and god bless
GE HotPoint HSS25 not cooling, but interior lights...
My HSS25GFPJWW was making a clicking noise and seemed low on power (lights would dim when dispensing water), but now it looks like nothing...
freezer work's excellent,, but fridge part is
freezer work's excellent,, but fridge part is getting warmer every day now and will soon not be able to keep food cool. Have freezer set...
My frige stays warm all the time it is a Hotpoint
Hotpoint sidebyside frige
WHAT COULD BE WRONG WITH
WHAT COULD BE WRONG WITH MY REFRIGERATOR? I laid my frige on its side when I moved to a nothe home, I didn't plug it in untill 20 days...
Add Your Solution
water is leaking from the
water is leaking from the freezer into the refrigerator.
The FREEZER of my GSS22SGRF
The FREEZER of my GSS22SGRF SS refrigerator/freezer keeps filling up with frost and ice....it is not defrosting....and...
frig is warm, model hth16bbsxlww, not seeing a
frig is warm, model hth16bbsxlww, not seeing a dial on top of frig compartment for advancing the defrost timer
GE Hotpoint refrigherator with freezer
GE Hotpoint refrigherator with freezer on top. Freezer door was left open just a little for 12 hours. Food was not...
Fix-O-Meter
1,387
1,387 people viewed this problem
- 0 people are following this problem. Be the first!
Top GE Refrigerator Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
