Question about Acer Computers & Internet
High pitched squeel from the hard drive and then shuts down.
My hard drive emitted a high pitched squeal and then shut down. About 30mins later I turned it on and it has been fine since {2 days later}. Normally when I turn it on I have to put in my password, but since the initial problem, the box doesn't come up but goes straight to the desk top. A couple of weeks ago the hard drive had repairs done to it and when I got it back the repairer had lost some of my files and changed a few things.
    Top Expert:
  • 12,223 Answers
Restart the computer HOLD the keys CTRL +F11 OR F12 depend of your mark, model, and go restore to the factory default, and fix it.
Passs the antivirus+antimalware very IMPORTANT!
God bless you
Posted on Jul 20, 2013
  • 4234 Answers
SOURCE: Computer
Look at the capacitors on the motherboard. These are cylinders scattered all over the place. The tops should be flat. I would suspect that some of them are now bulged up. This means that the main power lines are not being filtered correctly. Over time this will result in oscillation which is what you hear. These parts can be replaced by anyone with experience with multi-layered Pc boards. Let us know if you still have the problem.
Dan
Posted on Mar 31, 2008
SOURCE: High Pitched Squeal
none of these help me at all,this is plaguing my laptop to the point where it is not operational
wtf?
Posted on Oct 20, 2008
SOURCE: Start up repair and recovery
Thank you for your response.
I finally did get it fixed yesterday with help from an Acer agent on the phone. I had to re-install the OS, and loose all my files, but none that I can't replace. The pop did sound electrical, but it hasn't done it since I've re-installed the OS. The computer is only around 8 months old, and I stild have a few months of the one year warranty left on it. Before it all happened I installed Windows Messenger Along with my Yahoo Messenger, and Was using a few registry cleaners, in which I may have accidentally deleted something in the registry. Anyhow, it is back to normal, and Im gonna be a little more careful with these registry cleaners, and as soon as I get the extra money, Im gonna get me an extra external drive.
Gary
Posted on Mar 17, 2009
GoTechNinja
  • 12 Answers
SOURCE: power pack beeping, no lights turning on
Unfortunately your laptop is suffering from hardware failure. You may try removing the battery and using only the power cord.If this solves the problem then you either have a defective battery or bad power circuitry on your laptop. Aside from that if its still under warranty sending it to Toshiba for repairs will be your safest and cheapest option.
Posted on Apr 16, 2009
myrlex
  • 674 Answers
SOURCE: i have a compaq presario sr1103wm and it won't
re install or repormat your system to fix all problem will return into normal operation... but before that dont forget to save your data if you have important data dont'want to loss it..
if can't open the program or operating system remove your Hdd then insert into another computer to back up the data ot be sure that you have back up all important data. except those programs cant make back up... you need to re install again from the source..
Posted on Sep 17, 2009
I have a Dell Latitude D630. When the laptop is switched on it emits a high pitched scream and will not boot. I disabled microphone in BIOS and machine boots fine. Re-enabled microphone and same probl
It sounds like a driver problem, normally the microphone is off on-boot-up. It should only be opened by a program wanting to use it.
Have you tried turning it off in the operating system, rather than the BIOS?
Download the correct drive here.
Product Support Dell US
Feb 11, 2015 | Dell Latitude D630 Laptop Computer PC...
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
Jun 30, 2017 | Haier CPRB07XC7 Portable Air Conditioner
How do I stop my toilet from emitting a high pitched squeal when the fill valve shuts off?
You will have to replace the fill valve...or sometimes you can try to readjust the fill level using the adjustment screw....that may help
Please rate me
Dec 04, 2010 | Toto Carrollton Toilet Tank - ST774S-01 -...
High pitched noise regardless of power on/off
Hello... I would say that your power supply is going bad. But it does sound like the little muffin fan in the unit is.
May 10, 2009 | Panasonic DMR-E85H DVD Recorder
Samsung 42' Rear projection - High freq squeal
solder around pins on flyback transformer,see if this will solve your problem.some flybacks will make this sound, like a ringing noise.
Jan 19, 2008 | Samsung HC-P4241W 42" Rear Projection...
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
Computers & Internet Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
