Question about Russell Hobbs 15081 Steamglide Iron In White And Blue, 2400 W
How to change lead on russell hobbs steamglide
Need to replace elecric lead how do I split iron to gain access to rebove old lead
SOURCE: Russel Hobbs iron: The element is ok, but the iron
maybe descaler needed the holes blocked limescale
Posted on Feb 10, 2011
caroldon
  • 17130 Answers
SOURCE: My Russell and Hobbs Professional
it is important to check the continuity of the coil as the power indicator is a neon and will show up as the power comes to the circuit. So what is required is to check if the coil or the thermostat control is defective and so does not heat.
If you can contact the Russell hobbs web site - support and post the part code of the set it will be traced to be under warranty and it is possible that you can get support for help...just in case the coil has opened.
Posted on Apr 01, 2011
heatman101
  • 43501 Answers
SOURCE: What is the best way
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaninga Steam Iron Soleplate
heatman101
Posted on Apr 02, 2011
caroldon
  • 17130 Answers
SOURCE: My russel hobbs iron is
This is a problem with the thermostat- possible that the bimetal is stuck or short or changed in alignment causing the power to be connected at all times and not cutting off.If you can remove the unit then this can be seen by checking the cut off of the control.
Posted on Jul 01, 2011
SOURCE: I have so far seen
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Posted on Aug 21, 2011
Hi l have a Russell Hobbs steamglide iron and l cannot remove burnt marks of the bottom could you please help me with this problem? Thank you Rhonda.
There are three ways.
1. Easy Off oven cleaner.
2. Flitz Chrome and Metal cleaner
3. Stand it is a tray of Household Ammonia for 24 hours. Put the whole lot in a garbage bag to reduce the fumes.
May 12, 2018 | Russell Hobbs Irons
How to replace flex on Russel Hobbs Steamglide 18651
Either it'll have a screwed on plate near where the cord enters the iron, simply open, snip out the old, solder or crimp in a new and replace the panel. If not you'll have to replace it
Oct 07, 2014 | Irons
Too hot to handle spits water from sides Bosch sensixx B10L
I just fixed mine - it had exactly the same problem.
First, though, check it's not within the Bosch TWO year guarantee; if it is, they'll either fix or replace it.
If it's not under guarantee then the problem is probably the rubber tubing that connects the external steam tube to the hotplate. You'll need to dismantle the iron. Mine had split right next to the spring clip that holds it on. I shortened it, clipped it back on and all is now well.
Dec 22, 2012 | Bosch sensixx TDA 8333 Iron
HI I have a Bosch Sensixx B25L iron. Steam isn't coming out of holes, seems to be escaping from edge of iron. Handle very hot (Too hot to hold on to), burns your hand when steam button is pressed
Jul 28, 2012 | Bosch sensixx TDA 8333 Iron
Instrution manual for russell hobbs 17880
i need an instruction booklet for a russell hobbs steamglide iron model number 17880 any helpers please .
Jan 20, 2012 | Russell Hobbs Irons
Russell Hobbs 15081 Steamglide Iron In White And Blue, 2400 W Logo
149 people viewed this question
Top Russell Hobbs Irons Experts
 Mikey
Mikey
NOEL
NOEL
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
