Question about Samsung Televison & Video
Samsung model le32s62b
Picture poor, green waves in the picture sideways, plus other lines. Sometimes picture rolls. Sound has electronic noise (like interference) in the background, beeps occasionally
  • 1153 Answers
SOURCE: Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
Posted on Sep 14, 2007
SOURCE: 46" toshiba dlp projection picture problems
Take out the lamp and clean it. Look inside where the lamp was and you will see a thin peice of coloured plastic (colour wheel). Vacuum that plastic and all around it but don't touch it. This solution worked for me, and now my TV is as good as new.
Posted on Dec 28, 2007
SOURCE: Samsung LE40R51B no picture but turns on
i have the same problem i was told by a repairman that samsungs are known for bad psu. and that its expensive to repair
Posted on Feb 05, 2008
phongnv
  • 56 Answers
SOURCE: samsung big screen tv model pcl542r has a green or red tint to picture
This is for the 50" Vizio TV,
It sound like the control board has a problem. There is two way to fix this.
- Upgrade the firmware of the control board, If you can find the firmware upgrade device.
- Replace the control board (I think this the best solution)
Posted on Feb 16, 2009
rustym62
  • 201 Answers
SOURCE: poor picture quality and loud buzzing noise
Sounds like your color wheel is failing they make a loud sqeauling noise when they begin to fail.Run you somewhere around $300-400 to have a tech repair it.
http://the-tv-dude.blogspot.com
Posted on May 04, 2009
There is a humming in back of tv.the sound always good but picture doesnt come thru and i get a green screen someetimes blurry with distortion.color wheel or dmd chip or lamp starting to go out
as my experience, the most possible reason should be the color wheel or its photo sensor board.
firstly try to clean its photo sensor board, or have to replace a new wheel.
i just have this wheel, when you need to replace it, contact me freely
May 02, 2016 | Televison & Video
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
How do I fix wavy lines on Hauppauge Wintv hvr950q?
Are they wavy lines throughout the picture or are they just wavy on the side? Waving picture is usually caused by poor power supply filtering. Wavy lines throughout the picture are caused by interference. Try moving the device away from the computer with an extension USB cable it may be picking up interference from the surrounding electronic devices. It could also be defective.
Oct 19, 2014 | Hauppauge WinTV-HVR-950Q (1191) TV Input
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
The pictures have horizontal lines
This is electronic shutter problem that is the reason you get blinder effect/ noise on picture. Electronic shutter is located in lens mechanism and lens assembly will be replaced to solve the issue. Nearest Samsung service center or local camera repair shop will help you to replace lens assembly.
Thanks.
Aug 03, 2010 | Samsung S630 Digital Camera
Picture is black and white
Does it sound like thin grinding noise?
The color wheel is very common problem. Color wheel for this model is about $100 to $150 plus labor.
Nour BMI
Feb 18, 2010 | Samsung HC-P4752W 47" Rear Projection...
Poor picture quality and loud buzzing noise
May 03, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Sound but no picture
If PIP works, have you tried to swap pictures. You may have a tuner out.
Jan 20, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
No sound or picture
What is your model number
Jan 08, 2008 | Televison & Video
Televison & Video Logo
Henry  Thomas
Henry Thomas
