It will run on half choke. will not run on open choke .it is a mcculloch fr56. weedeater.
HI,
I TALKED TO MY SISTER WHICH IS AN INSPECTOR FOR WEEDEATER COMPANY SHE TOLD ME IT HAS CLOGGED FUEL LINE OR THE TANK IS DIRTY. ALSO CHECK THE PRIMER BULB FOR HARDNESS OR CRACKING THIS ALSO CAN ALLOW A LEAN OUT CONDITION YOU ARE EXPERIENCING. EMPTY THE TANK AND WASH IT OUT WITH FRESH GASOLINE. SETTING FOR THE IDLE SCREW IS 1.5 TO 2 TURNS OUT WHEN TURNED OFF AND FULL THROTTLE SETTING IS HOLD THE THROTTLE WIDE OPEN AND TURN THE SCREW IN UNTIL MAXIMUM RPM IS ACHIEVED. HOPE THIS HELPS GOOD LUCK!
