Question about Acer Aspire One AO532H-2527 Netbook
Need primary unlock code
How to unlock primary unlock code
I need a code to unlock my ipod 4gb
Hi curtisyoung1...
If you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Please take time to rate me
Aug 17, 2011 | Apple iPod nano
Need default code for ipod nano the little one never put code and dont know it
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Please rate me...
Thank You
Aug 16, 2010 | Apple iPod nano
Need to unlock the screen
There are two options by which you can unlock the code on your ipod. Follow any of the procedures below to unlock your ipod.
Unlock with the Primary Computer
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Take care
Jul 19, 2010 | Apple iPod MA446LL/A MP3 Player
I put in a code and for got it and now it is stuck on lock
Unlock by Restoring
Take care
Jul 18, 2010 | Apple iPod nano 2nd Generation MP3 Player
I need a passcode for my Ipod
Unlock by Restoring
Take care
Jul 17, 2010 | Apple iPod touch 3rd Generation MC086LL/A...
How do i unlock ipod nano without code
there are two options by which you can unblock the code on your ipod. Follow any of the procedures tomorrow.
Unlock by Restoring
Good luck.
Jun 25, 2010 | Apple Ipod Nano Second Gen. Green (4 GB)...
My gradson forgot the code to unlock nano
Unlock by Restoring
Taker care.
Jun 04, 2010 | Apple iPod nano
How to unlock a locked ipod nano
to unlock the ipod nano you need to remember the code. If you cannot remember the code follow the steps below. If this doesnt work please let me know and i can assist you from there. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
May 09, 2010 | Apple iPod nano
Unlock screen lock code number
Unlocking iPod You can unlock iPod in one of two ways:
  • Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen.
  • Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
If you want to change the primary computer that your iPod is associated with, do this:
  1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
Feb 27, 2010 | Apple iPod nano MP3 Player
I4 got my code 2my ipod how do i unlock it
  2. Open iTunes and sync the iPod as normal.
  4. Unlock by Restoring
  5. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  6. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  7. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Sep 25, 2009 | Apple Audio Players & Recorders
Acer Aspire One AO532H-2527 Netbook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
