Good mornig my dvd writer copy on Nero but don't
    Sergeant:
  • 376 Answers
Make sure the drive is listed in Device Manager first. If the drive is missing from there, it will not function properly.
Posted on Jul 06, 2014
SOURCE: Samsung DVD writer SH-S182 problem
try a different power connector from psu,do not share same as HD!!should work!!
Posted on Dec 10, 2007
  • 58 Answers
SOURCE: problem with hp dvd writer 740b
try to reinstall windows. its not your optical drive. also after reinstalling windows, download another burning sw. then see if it burns ok.
Posted on Feb 16, 2008
SOURCE: Serial number for nero 7
i downloaded the nero 8 trail version from the net but it needs a serial key to activate please send me the serial key for the activation and aslo tell me how can i crack it to make it full version
Posted on Sep 11, 2008
  • 146 Answers
SOURCE: dvd writer does not burn on raw file system cds
What OS are you using? I doubt it is the burner. I have the same model burner and it burns everything I try to burn just fine. It works on both my XP SP2 installation and the OS X86 Leopard 10.5.5 installation. I have burned video, data and bootable OS DVDs and CDs in both operating systems.
It may just be Nero. You could try Alcohol 120% or Ultra ISO.
Posted on Dec 27, 2008
NitrusInc
  • 326 Answers
SOURCE: HELP!!!!! : "Not found CD/DVD Writer driver"
This could be due to a common issue. I would suggest you try this method first.
The following is a link to the Microsoft documented solution for issues with DVD/CD drives, explaining a step-by-step procedure. In the event that the first process, which is automated labeled "Fix It" does not solve your problem, please continue to the end of the document.
http://support.microsoft.com/kb/314060
After completing this procedure, please let us know if you are still experiencing any issues by posting a comment. If this information was helpful, please take a moment to rate the solution. Thank you
Posted on May 17, 2009
Testimonial: "thanx"
Why wont my emachine desktop burn data onto a dvd disk
First check whether you have a DVD writer or not.
1)If you drive is a DVD writer a DVD-RW will be written on top of the drive otherwise it is not a dvd writer...so obviously it will not write a DVD.
2) If the drive is a DVD-RW then you need a burning software to burn diske. Please download any valid burning softwares from the interne such as 'Nero' or 'Power iso' and install the same in your pc to burn dvd.
If you feel that, my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Oct 25, 2011 | E-Machines W3410 PC Desktop
No how i can get nero smart for my compaq 610 asus dvd writer i m using window7
Nero 9 is a free burning utility available through the Nero software company that allows users to burn audio and video files to blank CDs and DVDs.
Just search 'Nero 9 download' on google.
Aug 20, 2011 | Compaq (158165-001) DVD Drive
Can't play some dvd video. Dvd hired in shop is OK, but other recorded dvd and clean dvd is rejected as no dvd or can't read.
The store hired DVD's are molded DVD's and would work well on any player. The DVD's written on a writer should be first written at the slowest speed you can as DVD's written at higher speeds cannot be read by a lot of players. Are you maintaining the same structure of the DVD while writing? Do a DVD to DVD copy if you can and not after copying to Hard Disk. Some software have an option for setting the DVD compatibility such as in NERO Burning Rom DVD high compatibility mode in writer settings.
Jan 16, 2011 | Televison & Video
My drive will regognize and burn cds but when i try to watch or burn a dvd it says unkown or invalid its an hp dvd writer 420n
install the corect hp drivers and check the windows settings to make sure it is not sean as a cd drive instead of a dvd
Aug 03, 2009 | TDK Indi DVD 420N (AID+420N) DVD+RW Burner
Copy picture from computer 2 dvd/cd burner/ hp dvd200i
First copy all files from your cam to your harddrive.
Locate the files and use a program like NERO Burn, that supports DVD Writer and you should be set. Ifyou dont want to buy NERO, you could search Google for a freware burner software that will do the same.
IF you Win Vista, you can burn DVD's by right clicking the file and then Select " Send to" and DVD
Good luck
May 10, 2009 | Samsung S860 Digital Camera
My lite-on DVD writer is not reading any dvd's as well not writing any DVD's while it is good for CD's..... What is the problem?? How can i correct my DVD writer
Hi Please try and use a different brand of DVD discs. DVD disc quality is sometimes an issue with lite-on drives Also check that you have updated drivers and your media burning software is installed correctly. Again if your using NERO this can be a problem. Try using any other burning software One other thing to try when recording DVDs set the recording speed to lowest Many Thanks Andy
Apr 27, 2009 | Computers & Internet
DVD writer not working
Let's make sure that Nero is not causing the problem. Try this:
-Insert a blank CD or DVD
-Find a file that you want to burn to disc
-Right-Click on said file and select Send To --> DVD-RW Drive (D:) (or whatever your recordable drive is labeled)
-Open My Computer, double click on your recordable drive
- You should see your file ready to be burned to disc
- In the left-hand panel, you should see a link that says "Burn these files to disc" or something similar - click this link and see what happens
If this process works and properly burns a disc, your issue is not with your drive but with Nero. If this process does NOT work, then you may need to reinstall drivers for your DVD writer or replace the drive if it is faulty.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 11, 2009 | Compaq 6710b Notebook
How to record from a website to cd on laptop
To burn cd/dvd you have to check :
1. Your laptop cd/dvd drive have what capability:
- cd writer = only burn cd
- cd writer/dvd reader(combo) = still only burn cd
- dvd writer = can burn cd, dvd single layer(4GB)
- dvd DL writer = can burn cd and dvd single 4GB and dual layer 8GB.
Other than those, is not possible.
2. Must have burn apps named:
- Nero
- Alcohol 120%
- other. search internet.
If you have them then using the apps to burn, just read the manual.
Koam114 is in Korean. I don't understand :)
But If you want songs from website, you should download it first.
Unless the site is giving you a step by step how to burn songs directly to your cd/dvd.
Once downloaded, would be easier to burn to cd/dvd.
Dec 26, 2008 | Toshiba Satellite L305-S5907 Laptop
DVD Writer not burning
I have come across this quiet abit. U could try updating the firmware but I would say that the lazer is past its best. I presum it still read the cds fine? I would suggest getting another drive if firmware update doesnt work
Oct 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
How to copy a dvd or cd
all you do is put the disk u want to copy in one drive and the blank disk in the writer load nero choose discopy then click burn should then do it regards
Sep 29, 2007 | Ahead Software Nero 6.0 (60045) for PC
Computers & Internet Logo
David Payne
David Payne
