Sony rdr hxd995
Update on front panel won't turn on
  • lynn Jul 20, 2013
    Mine also has this problem
My Dad and myself both have the same model HXD995 - Both stopped working last night with no channels and now stuck on Update.
Posted on Jul 20, 2013
5 Suggested Answers
SOURCE: New Sony DVDVCR RDR-VX560 seems to be locked up
Problem was solved by Holding down the "ENTER" button for no less than 10 seconds and after releasing it press "SYSTEM MENU". This will take you to the setup screen on your TV.
where all settings can be made from there by following the on screen directions.
Posted on Jun 23, 2009
bob_computer
  • 3153 Answers
SOURCE: How do I make my Sony RDR-HXD995 recorder multi-region?
After getting clarification from Fixya I can pass the links below to you to check yourself
Some players are harder than others to do this but you may want to
try here
or here
Comments:
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one.
Just a thought
Posted on Sep 19, 2009
Obertelli
  • 3006 Answers
SOURCE: HI My Sony HXD995/HXD1095 will not recorded
The official advice for failed retunes is to repeat the process. From experience I'd suggest to try twice but at different times of the day.
Having said that there are a lot of Sony products which have been listed as having problems with the retune; mainly where the Freeview functions freeze, your model is not on the published list of affected units but it's become painfully obvious that the list is not a comprehensive one. If you are certain that you have a good aerial system then the next step will be to follow the advice on the Sony website:-
http://sonycic.custhelp.com/cgi-bin/sonycic.cfg/php/enduser/std_adp.php?p_faqid=221&p_sid=7-JakZJj&p_lva=369&p_accessibility=0&p_redirect=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD00NTgsNDU4JnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTE*&p_li=
If this fails then contact Sony on 0870 511 1999. As the phone lines will undoubtedly be busy you may also wish to consider getting assistance via the Sony UK website:-
http://support.sony-europe.com/hav/hv/dvr/dvr.aspx?site=odw_en_GB&m=RDR-HXD1095
See below for a (non-comprehensive) list of affected products.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
Posted on Oct 09, 2009
  • 8457 Answers
SOURCE: Sony RDR-GX360 won't respond to
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Posted on Aug 11, 2011
Error e02 sony rdr hxd995
Not enough data to make a proper solution to your problem. Be more definitive and detail what it is you are experiencing.
Dec 12, 2013 | Televison & Video
Sony hdmi hxd995 how to remove update off panal
Is this an update from Sony that has gone wrong.
My HXD995 display is also showing UPDATE and will not do anything from 20th July 2013 (same as OP)
Any one know how to do a factory reset (I/O & Stop doesn't work)?
or how to reject the update?
Jul 20, 2013 | Televison & Video
Program ur5u/mdvr to sony rdr gx357
Possibly, it won't hurt to try, the machine will not be harmed.
May 21, 2012 | Sony Televison & Video
How to remove childlock
Hello
To unlock the receiver from child lock, Press '/Power ON button on the recorder. The recorder turns OFF and ' CHILD LOCK' appear on the display. The timer indicator remains lit if there is a timer setting. The recorder will not workexcept for timer recordings.
To unlock the recorder, Hold Down '/Power button on the front panel of the recorder itself, until the "CHILD LOCK" display disappears from the front panel display.
Mar 02, 2012 | Sony RDR-VX515 DVD Recorder/VCR
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
I want to dub from tape to disk on an rdr-vx530. must i have it hooked up to a tv etc? can't i just use the rdr-vx530
You can, yes. But you won't be able to see what you are doing, thereby making sure things are functioning the way you want them too.
Aug 29, 2011 | Sony RDR-VX530 DVD Recorder/VCR
Remote RMT-D240A not working with RDR-VX525 DVD Player that it came with. Only get DVD Screen saying DVD 3, will not even turn ON/OFF.
You may have to reset the remote to the current command code. Here is the link for how to do that. http://community.sony.com/t5/Remote-Controls/RDR-VX525-Changed-to-DVD3-on-command-control-and-remote-won-t/td-p/158777
Dec 17, 2010 | Sony RDR-VX525 DVD Recorder/VCR
Oct 09, 2009 | Televison & Video
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Televison & Video Logo
323 people viewed this question
Top Televison & Video Experts
Electro Med Services...
