Question about Lands Phones
Beetel phone circuit diagram
I have a beetel M53 model landline phone. the problem is , aftera call when I put the receiver on base the loudspeaker starts to ring continuously. I tried to press the speaker button to off it, but it doesnot work. pls help me to solve this.
  • 4 Answers
SOURCE: Panasonic Phone KX-TG2432
I have the same probloem with a KX-TG 5672. I am going to call 1 800 2111 7262 on Monday and ask for technical support. If you get a solution, pls notify me.
Posted on Jan 26, 2008
SOURCE: Speaker phone light continually blinks
The blinking light on the speaker button means the forward when busy is on. To cancel it- With the handset on-hook dial #12.
Then press your own station number. Then dial # again. The speaker button should stop flickering.
Note: If the SPK button continues to flicker, Forward all is activated. It is the same process as above but use #11 instead of #12
Posted on Mar 12, 2008
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
SOURCE: GE 900mhz model 26936GE2-C
HI NEED HELP MY PHONE IS SAY NO LINK TO BASE
Posted on Jul 03, 2008
SOURCE: Binatone E3300 no dial tone, anyone have a manual?
USPJEH !Problem sa mojim binanotone 3300 je riješen. Napominjem da se kvar ogledao u tome da je na displeju telefonske slušalice bilo prikazano h b bez oznaka i da je stalno treperilo. Način na koji sam otklonio kvar je sljedeći: pristisnuti PROGRAM 1 0 i potvrditi zelenom slušalicom da se resetuju tvornične postavke, na centralnoj jedinici telefona-BAZA- pritisnuti tipku za registraciju, dr?ati tipku pritisnuti dok se ne čuje bip, nakon toga u roku od 30 sekundi ukucati PROGRAM, pa 1 6, nakon toga oznaku telefonske slušalice kod mene je bio slučaj da je to druga telefonska slušalica pa sam pritisnuo broj 2, nakon toga pritisnuti četiti nule 0000 i potvrditi zelenom slušalicom.
SUCCESS! Problem with my binanotone 3300 is resolved. Note that the defect was reflected in the fact that the display of telephone headsets hb without showing any mark that is constantly flicker. The way that I remove the defect is as follows: pristisnuti PROGRAM 1 0 and confirm the green headset that tvornične reset the settings, the central unit of the phone-BASE-press registration, keep the key press until you hear a beep, then within 30 seconds to type program, and 1 6, then the tag headset phone with me has been the case that this is the second receiver, so I pressed the number 2, then press četiti zero 0000 and confirm the green headset.
Posted on Nov 01, 2009
Panasonic DECT 6.0 cordless phones system has begun dropping calls after first ring also won't take messages
Firstly, disconnect all devices / base unit from your landline. Then, using a mobile phone, dial your landline number. Does the ringing tone in the earpiece continue or does it stop after one ring? If it stops then you have a line problem which you need to report to your service provider.
Apr 27, 2017 | Panasonic Lands Phones
On my landline phone. how do I limeted the number of phone rings?
Only answering machines have adjustable number of phones rings, not standard telephone, it rings until answered. Remember this answer is based on the information you wrote in the problem question .
Nov 02, 2016 | Lands Phones
Would like to increase the number of rings before the answer machine starts.
Look again, gotta be threre - if still cannot find just enter "changing rings for ----" on google and see what pops up.
Aug 28, 2015 | Lands Phones
ZTE MF190 Dialing problem
I have a unlocked ZTE Mf190 USB-Modem. When I put the SIM card in it and connect it to the computer, I am able to connect to 3G Internet via beetel connection manager. Is it also possible to send and receive SMS. But when I try to make a voice call on beetel voice call panel, I receive this error message "Dialing failed! Please try again!" . And also when I use another phone to call the SIM card line number that I put in the USB-Modem, I receive busy tone
Mar 31, 2013 | ZTE Mf190 Unlocked 3g Gsm 7.2 Mbps...
My Acer X960 phone makes screeching sound when I receive a lot, hence I cannot hear the opposite party.
Sounds like your speaker has gone, when you next get a call put it on loudspeaker, it should solve the problem, as its a different speaker, you can put it in loudspeaker from options menu when you get a call.
Jul 10, 2012 | Acer X960 Black Quad Band With 3g Hsdpa...
I have no sound from the earpiece when ringing a number, although it does ring out OK. It rings and receives calls Ok but I cannot hear the caller, except by putting it to loudspeaker. In all other...
sir while you answering the call press the volume button to increace the sound [or] give to the nokia service center for replacing the new earpiece mic for getting better volume................
Nov 26, 2010 | Nokia 6700 Classic Cell Phone
My landline phone won't ring, but I can get and make calls!!
My experience with an old (100+) and newer house is that it is important to make sure your telephone wires coming into the house, and the junction block where all the wires connect, stay clean and dry. If the wires can get damp or dirty, then when that 90 volts of ringing voltage come down the line, it may find a low impedance path. At my old house I had to make sure the outside wires didn't touch the ground or get damp. In my newer house, I discovered the wiring block was near a dryer vent where it got a ton of fuzz on it, plus the moisture, so eventually our phones stopped ringing even though we could make calls and our DSL was not affected. When we exposed and cleaned up the wiring block so that the phone company tech could re-visit us to troubleshoot things, suddenly it started working again.
Nov 25, 2009 | Lands Phones
Phone not ringing
dude i think your phone is on silent go to your profile settings and check that al is set right.
Mar 06, 2008 | Nokia e65 Cellular Phone
Lands Phones Logo
107 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
