Question about Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan
Cannot Sync Honeywell Fan Wall Control with Remote
Hello, I just got the Honeywell Ceiling Fan Remote&Light Remote With Wall Control (Light &Air Control Plus) Model #40015. I have followed all instructions as did my licensed electricians but cannot get the remote to sync with the wall control. They are supposed to be ready to go but there are instructions in case the two do not communicate right out of the box. The remote does not work at all but the wall control is fine. One of the troubleshooting ideas is to check to see if the antenna from transmitter is visible. The electrician checked and there was no way to get the antenna out and visible from its location. I have reset the power and the junction box each time that I tried to follow the directions of doing that plus holding down the fan off button for three seconds. When I do that, I do get the blinking lights three times per instructions. Then, I hit the fan off button again per the instructions. It is supposedly in Smart Sync mode at this point. Anyway, I cannot imagine wha?t we are missing here. Perhaps the documentation is incomplete.
Buffalo12980
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
SOURCE: Older Model Hampton Bay Ceiling Fan: The Redington II w/Remote Control
Ironically, i am having the same problem with TWO different Reddington's in my house.
One is brand new, just hung a few weeks ago, the other is about 3 years old.
The new one -- the lights are stuck in a constant dim, bright, off, dim bright off, and the fan wont turn at all.
The old one, the lights wont come on and the fan will only spin slow.
Both failed within a day or two of each other, and this is driving me nuts.
I thought it might be the remotes, so I took both remotes and pulled the batteries out of each, but that didnt do anything.
If anyone else is having this problem, please post.
Posted on Jan 13, 2008
  • 158 Answers
SOURCE: Ceiling fan stuck on high
Try removing 120 volt power from the fan by turning offf the house circuit breaker or removing the fuse from the fusebox that supplies power to the fan. Wait 30 seconds and restore power. This may reset the fan speed control in the fan itself.
Posted on Aug 05, 2008
WeListen2You
  • 538 Answers
sounds like the radio signal amp is blown..that is a full replacement deal..that would explain this, and the power
#glitch could certainly cause this problem..
Posted on Oct 26, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
Remote not operating with ceiling fan
Hello, Aileen -
If you have not installed a fresh battery in the remote control for your ceiling fan, do that.
Another thing to consider, you may need to have a wall light switch (which is connected to your ceiling fan) turned on before the fan can operate. That is the case with our ceiling fan, which also has a remote control.
Without knowing the make and model of your fan, it is a challenge to provide you with more assistance. You can add the make and model of your fan by choosing Comment and typing the information in the Comment box.
Best wishes.
Mar 10, 2018 | Miscellaneous
I cant cut my new ceiling light off from my wall switch aftetreplacing ceiling fan what should I do
What is make/model of fan. How do you change speeds(wall control,remote,pull chain) & how do you turn light on/off?
Oct 30, 2015 | Dryers
Why Ceiling Fan Fixture does not work
You get what you pay for! Shouldn't buy a store brand.
Jul 14, 2014 | Hunter 52" Ceiling Fan With Light And...
Fan on the ceiling fan works, light does not, it is an Emerson unit wall switch only not remote control
Try pulling the chain once and then try the wall control. Is it a wall REMOTE or dual control? Do you have the number of the wall control?
Aug 31, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Hampton Bay Ceiling Fan - remote problem
Hello Espanbauer,
KEEP in mind it could be the receiver also
(cheapest & best first guess is the REMOTE).
I get all my REMOTES from eBay...
(Although AMAZON does sell these)
Believe it or not if they are advertised as GENUINE & new
and come from ESTABLISHED sellers... You are well
protected by both eBay & PayPal
ALWAYS pay close attention to SHIPPING COSTS
LOOK here:
Genuine Hampton Bay Ceiling Fan Remote Control UC7078T with Up Down Light...
InTHIS price range
Hope this helps
Carnac the Magnificent
Sep 20, 2017 | Hampton Bay Dryers
I need a fan control UC-9160-1C for ceiling fan AC 522 ,or a replacement.
If this is a switch for a Honeywell ceiling fan, I have two new UC-9160 wall controllers. I can sell them to you.
Sep 04, 2009 | Honeywell Dryers
Wall switch
I had this same problem (sort of) - my daughter lost the remote to our fan and it would not work from the wall switch. What you have to do is go up to where your fan is connected to the ceiling, slide the canopy down, and remove the remote transmitter. Then just rewire the fan normally - white to white, black and blue to black, and the ground wires together. Turn on the power and your fan light should work with the wall switch. You will have to pull the cord for the fan to work.
Jan 07, 2008 | Honeywell HFS641P Stand (Pedestal) Fan
Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan Logo
657 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
