Question about Fujitsu New Original ARRAH2U Remote Control
How do I turn off the timer function - Fujitsu New Original ARRAH2U Remote Control
    Top Expert:
  • Fujitsu Master
  • 12,223 Answers
You must go to the Menu, and and go sleeping section and proceed. However you can download the owner manual go
www.retrevo.com
God bless you
Posted on Jul 20, 2013
HI,I installed a GE digital timer model 15313 about two years ago.Now cannot turn on or off manually or program it. But it does turn on and off the times I programed the last. Thanks
Try reset and reprogram
If functionality is not restored, then replace timer.
Note also the load rating for each timer.
If you are operating above or outside the load parameters for timer, then timer might not function correctly or function as long as expected.
This timer, and most timers have 1 year warranty.
http://waterheatertimer.org/GE-timers-and-manuals.html#15313
Suggest replacing with 5-year warranty Ei600
Can operate any load value, LED fluorescent incandescent motor
Has dawn-dusk or programmable mode
http://waterheatertimer.org/Programmable.html#st01
Gene
Sep 02, 2014 | Hardware & Accessories
Water heater timer
If everything is wired correctly, the timer switching function may be no good.
Nov 11, 2013 | Intermatic WH40 - Water Heater Time Switch...
Intermatic dt8003
Copy following link to help identify timer and download product manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT8003
If this is not your product, add a comment and describe timer in detail. Otherwise we're guessing at your product.
The 8003 power strip timer has 4 outlets that are controlled by timer, and 4 outlets that operate normally without any timing function.
It appears you can press the Mode button until ON is displayed, and that this mode will not change until Mode is changed again.
However, if timing functions resume at next set point, then re-program timer so it is ON 23 hours and 59 minutes each day, and turns OFF 1 minute each day... or just go buy a new power stripe without timer functions.
Gene.
Jul 24, 2013 | Hardware & Accessories
I have a newlec timer channel plusxl model nlh37 unable to programme it after it was switched off, all heating systems running at same time
1) Power surge such as turning power ON can put out timers.
2) Reset timer, and if functionality is not restored, then replace timer.
3) These timers usually have 1 year limited warranty.
4) Add comment and include photo of timer. And post your .pdf manual on your website, and include link to manual so timer and steps for reset can be ascertained.
Dec 13, 2012 | Hardware & Accessories
I HAVE A DIGITAL TIMER USED AT MY SCHOOL I REPLACE THE BATTERY AND IT WONT TURN OFF THERE IS NO ON/OFF SWITCH
Timer is not identified.
It's hard to know what is happening without know which timer.
Add a comment with clear description of timer or include photo of timer posted on flickr for possible help.
If battery operated timer has malfunctioned, try resetting timer.
Generally if timer functionality is not restored by reset, and will not function, then timer has probably gone bad.
Most timers have limited 1 year warranty.
Some Intermatic 120Volt plug-in timers have limited lifetime warranty:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#digital
Some expensive industrial/school timers have replacement computer chips.
Jul 21, 2011 | Hardware & Accessories
How do we set the time to stop on a UPM ETW350? I know how to set the time to start but i do not know how to set the time to stop. Thank you
In wall timers and manuals are shown on following link.
http://waterheatertimer.org/Programmable.html#ETW
ETW350 manual:
http://waterheatertimer.org/UPM-etw350.pdf
Select from 3 different functions:
1) 24-hour Programmable
2) Countdown timer function so lights turn off after period of time
3) Random function so lights turn on randomly and house looks lived-in
I am not going to write out the steps because they show in the manual.
But a specific part of the manual might be confusing.
So add a comment and I will help until we will get the timer working.
Nov 20, 2010 | UPM Programmable Wall Switch Timer
Time setting does not function. Clock doesn't cycle. Manual on/off functions and appliance turns on
As a general rule, if the timer clock does not rotate on plug-in-timers and in-wall-timers, then the timer has gone bad and needs to be replaced.
A larger box-type timer that attaches to the wall is different. For many of the box-type-timers, that are mechanical and not electronic, the clock motor can be replaced.
Oct 17, 2010 | Solar Intermatic Air Conditioner &...
How does the Timer and Sleep functions work for the SUMO KFR-70GW Heat Pump
Hi!!
On the timer function, when you press the button, it will ask you the starting time and ending time of when the unit will start and turn off by itself. prior to use this function, the clock on the control has to be set.. On the sleep function, it will give you the option to turn off unit on 30 min. intervals. Just like on a TV.
Aug 10, 2010 | Heating & Cooling
Does the FE-340 camera have a time delay feature so that we can take our own picture?
Please look for clock sign on buttons to turn on-off timer function.
Press clock symbol button to turn on timer function, press shutter button to start timer (10 seconds delay) to take picture.
Mar 14, 2010 | Olympus FE-340 Digital Camera
Soap door will not open during washing cycle
Well as controlling cycle times, the timer on many dishwashers also functions as an actuator for the spring-loaded dispenser door. At a certain specific time during the cycle, the timer will activate a lever that in turn opens the detergent cup. If that lever is broken or in some way defective, it will need to be replaced. Alternatively, the timer's motor itself could be the problem. If your timer is not functioning properly, then the dispenser door may not function properly either. Test your dishwasher's timer motor, and if it is broken, you can replace either the entire timer assembly or just the timer motor. Please post the model number of your dishwasher for more help or information.......
Good Luck!!
Thanks
Mar 01, 2010 | Maytag Dishwashers
Fujitsu New Original ARRAH2U Remote Control Logo
131 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
