Question about Toshiba Computers & Internet
Dvd seem stuck cannot eject - Toshiba Computers & Internet
    New Friend:
    Problem Solver:
  • 6 Answers
In you DVD bay there is small hole on it. Now you put the some pin on it then the DVD bay will come out.
Posted on Jul 20, 2013
How do I remove a stuck DVD?
It sounds like your problem isn't the dvd is stuck, since it seems to be spinning up, it sounds more like your ejection system has stopped working for some reason.
To fix either you are going to have to remove the outside case of the dvd player and expose the internal chassis. There are anywhere from 4 to 8 screws holding it on on the bottom and back of the unit, Make sure the dvd player is unplugged before you remove the cover.
Once you have the cover off, if the dvd is simply stuck, you should be able to see what the issue is; is it misaligned in the housing was it inserted incorrectly, are there in fact 2 dvds in the player, etc, etc. Gently remove the dvd and replace the case and enjoy.
If you can't see any reason for it to be stuck it may be the ejection system. The eject system will have a belt and sprocket system to move the tray or push out the dvd depending on the player. Make sure the belt is on the wheels correctly and that the sprockets mesh properly. If you can't see anything wrong try testing the ejection system with the case off.
Make sure you don't have any objects in or touching the dvd player, you don't want to short out any of the components if a screw fell into the dvd player onto the mother board, etc. Plug the dvd player back in, make sure you don't touch the inside and try to eject the dvd. Watch the ejection system and you should be able to figure out what is going wrong. Once you have figured it out unplug the unit and put the items back together. If you can see that something is broken then you will have to determine if you can have it fixed or if it wouldn't be cheaper to simply ditch that unit and purchase a new one.
Hope this helps.
Oct 12, 2015 | Televison & Video
Tip
My 2910 player has similar issue. The tray gets stuck on eject. Started with not...
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
bye
on Jan 06, 2009 | Samsung DVD-V4600 DVD Player/VCR
My Toshiba DVT80KB won't select the DVD or eject it.
Well...there's a slight chance that your dvd got jammed or stuck inside thus it doesn't allow you to eject or use it.Here's a link to solve your jammed dvd Hope it helps :D
Sep 18, 2014 | Televison & Video
Disney cars TV doesn't eject. The DVD seems to be stuck. Does anyone know how to fix that?
CD loading mechanism fault. Contact any service technician. Sometimes, a broken loading belt might be the reason.
Gopakumar Gopalan Google
Mar 25, 2014 | Disney Televison & Video
CD is stuck and cannot be ejected
mine does the same thing..cd or dvd gets stuck and will not eject or respond. this seems to be a common failure of this model..thoughts?
Apr 22, 2010 | Bose Lifestyle 20 System
I have a dvd stuck in a toshiba tv dvd combination
Try a reset on ur tv,Like unplug ur tv an hoour.Replug it back.Should get power to the DVD port to take out the DVD disk.
Feb 08, 2010 | Toshiba 23HLV87 23 in. LCD Television
Hp IQ780A has a2discs stuck in the dvd drive
Woah! You don't want to hear this but forcing a second disc into the drive has probably destroyed the drive read head. They are pretty tough and it might be able to survive but you will most certainly have to dismantle the drive to remove the DVD and not create any more damage. Kind of like scraping someone elses car in a parking lot. More damage is done when you try to back off of the other car than the initial hit. (not like that's ever happened to me :) )
Jan 08, 2009 | HP TouchSmart IQ770 PC Desktop
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Jun 19, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Computers & Internet Logo
15 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
