Question about Radio Communications
EWA speaker V2 pairing code - Radio Communications
  • David Cowan
    David Cowan Mar 18, 2014
    How do i retrieve my paring code for a EWA Bluetooth v2 speaker
How to pair
To Pair any items to a Cellphone, you do the following.
Let's say it is a Bluetooth speaker.
1. Switch the speaker on.
2. Set the Phone to Bluetooth Settings
3. Press Pair or Locate or Search on the phone
4. There is ALWAYS a button on the speaker or device you have to press to send the signal TO the phone. This is always the step people do not do. :>)
When the item is found, press 'Pair'. If it asks for a code, the default code is 0000 (4 x zero)
Nov 15, 2016 | Cell Phones
How can I get the blinking light to turn off on Bluetooth speaker?
Well first you have to get it to flash red & blue then try to get it to pair with your device
Mar 02, 2016 | Audio Players & Recorders
Main Speaker Not Working
IS there a circuit board inside that speaker? You are correct about the general loss of sound quality that usually occurs with speaker failure. Best way to check is with a meter or a scope
May 04, 2013 | Mackie SRM-450 System
Pairing manual for Craig CMA3532BT
To Pair:
1. Turn on your Bluetooth speaker (slide switch to BT)
2. Light on bottom should turn on Blue. If not, plug speaker into USB connector and bottom will turn Red to indicate it's charging.
3. Make sure Bluetooth is turned on your PC or Phone. Select device name: CMA3532BT.
4. Enter pairing code (passcode): 0000 or you can try: 1234
Apr 19, 2013 | Audio Players & Recorders
My Mackie 450 turns itself off why
Be aware that TIMED TURNOFF button at the back of the speaker is off otherwise every time sound level is low the speaker can go off by itself.
Dec 16, 2012 | Mackie SRM-450 System
I have a pair of mackie 450 v2 and a pro fx 8 mixer . where do i set the master volume/gain on the back of the speakers? i have followed the instructions from the manuals and seem to be ok but the meter...
hi, you do the right thing, usually the manual is not always right, the settings defend only on sound system set up, so if you have a good amplifier u will get the good sounds of you speakers. thanks
Apr 29, 2011 | Mackie SRM-450 System
When our my smart infocomm sc-12 webcam is connected to system,it occurs as the device usb connected to the system is malfunctioned.
Hi, I am unable to open EWA report of SAP in OpenOffice.org 3.3.I am able to view such files in MS. I have attached EWA file for your reference. Please help me in this regard. If any plug-in needs to be install please let me know. Regards, Niket kalamkar
Oct 03, 2010 | Computers & Internet
Where can I find the colour code for the wiring of a radio in a 2001 ford transit
the power feeds go to 1 block
get a test lamp and find the
switched live = goes to red
constent live = goes to yellow
ground earth = goes to black
speakers and dash display to 2nd block
speaker leads are matched in coloured pairs , use 9v battery to each pair to track speaker location, will buzz when hooked up to matched pair
Dec 04, 2009 | Car Audio & Video
Need to program sprint bluuettoth headset compatibable to v2.o
turn the bluetooth on, on the device .. then place the headset in pairing mode, search for the device from the phone then place them a foot apart once it finds the headset name it and it will ask for a code it is normally 0000.. then it will say device is paired and it will work
Aug 27, 2009 | LG enV VX9900 Cellular Phone
Radio Communications Logo
632 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
