Question about Car Audio & Video
Serious car troubles !! - Car Audio & Video
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Run a tank of vinegar through the fuel system then take out your spark plugs and dip them into a jar of Vaseline then reinsert the plugs also get a jar of peanut butter and smear a bit on those door hinges and I guarantee your car will run like a greased up peanut butter salad
Posted on Jul 21, 2013
Ive got a 93 ford ranger.after it gets warm & u cut it off for about 5 mins,& start it back its like it floods
Ford Check Engine light Codes - FreeAutoMechanic
www.freeautomechanic.com/diagnostictroblecodes7.html
Full list of OBD I Diagnostic Trouble Codes for your Ford Vehicle. If your Check engine light is on you may have a serious problem. Scan your codes and follow ...
EEC-IV 2 and 3 digit trouble codes. - Ford Explorer and Ranger ...
www.explorerforum.com > ... > EEC IV
Feb 6, 2007 - Serious Explorations Ford Explorer and Ranger Message Board .... 3.8L AXOD - Message center data link circuit fault - See code 70 73 (O) Is FORD DEALER the only place who can read out ABS error ...
Dec 5, 2011
Error codes 186 & 539.
Aug 15, 2009
OBD-II Diagnostic Trouble Codes (DTCs)
Nov 8, 2008
Have a Code? OBD II Trouble Codes Here
Jan 19, 2006
More results from www.explorerforum.com
EEC-IV Diagnostic Trouble Codes - Diagnose problems in
Dec 19, 2015 | 1988 Ford Ranger
Got brand new battery new plugs/wires car still doesn't start like it's suppose to do has a hesitation, spuddering got any ideas of what could be wrong
Ideas?
Sure... especially in the light of the new plugs... starting and sputtering: that's a really positive sign
Your exhaust system is the right age/mileage to be presenting serious issues.
In a well ventilated area...
Trouble shoot by using penetrating oil on the top flange BOLTS of the catalytic converter... loosen the bolts to allow enough space for a serious exhaust leak...
Put your ear plugs in... and see if the engines will start smoothly...
(success means you have a serious BLOCKAGE).
If not you are probably looking at trouble-shooting EVERYTHING about your fuel supply.
Start with fuel additives that absorb WATER... then with the filters, pumps, pressure regulators
Good luck and happy hunting
Nov 15, 2015 | 2003 Dodge Stratus
Oil wasfull severeknocking bad2worse in a day also coupleweek ago the temp was at 1/2 way point on gauge then it went over then finally ied&
Knocking : ticka ticka, clatter, or clunka clunka? Ticka may be lifters, timing, spark, or other not too serious. Clatter may be oil pump. Clunka -serious lower end rebuild. Dont run or might destroy chance to rebuild
Oct 07, 2015 | Cars & Trucks
My 2001 chevy blazer hiccups trying to accelarate. what would that be?
The first thing you do is have the computer checked for trouble codes.
The flashing light means the problem is serious.
The trouble codes will point you in the right direction to start testing.
Feb 18, 2013 | 2001 Chevrolet Blazer
My engine light on my chevy express is on,what is the problem?
The check engine light can be the result of many issues, some serious and some not so serious. The first step is determining what the cause of the light is by obtaining the trouble code. You'll need an OBDII scanner to do this. If you don't have access to one you can always take the car to your local auto parts store, most will scan the vehicle for free and give you the codes. Post the codes here and we can guide you from there.
Jun 29, 2010 | 1998 Chevrolet S-10 Pickup
The service engine light came on and started to have problems gaining speed and the light started blinking!
This is most likely a misfire. When the light blinks under acceleration it is telling you the engine is in serious need of service, which doesn't necessary mean that the engine is in serious trouble. Have your OBDII port and codes checked. Your local parts store like AUTOZONE will do this for free.
Jun 04, 2010 | 2002 Nissan Sentra
2000 VW Golf trouble code P1120
It can mean some points which can be faulty. It can mean that the ECU is totally failed or there us a serious electric failure. And thirdly, the most common thing that can happen is the Throttle Position Sensor which is also called TPS is defective, broken or out of range.
Please check the Car and call a technician who has mastery in repair because this code is serious.
Thank you Sir, Have a nice day.
Sep 26, 2009 | 2000 Volkswagen Golf
Trouble changing gears, car won't exceed 25 without grinding
This sounds like a serious internal transmission malfunction. It could be anything from thrust washers to bearings to planetary gears. In any case, the whole system is contaminated with debris from failing parts. The transmission has to be completely rebuilt and all lines and coolers flushed.
Sep 19, 2009 | 1998 Ford Explorer
1993 Camry takes a second or 2 to go into reverse ...Is this a sign of serious trouble ?
Serious trouble? Hard to tell witout seeing the car.
Do this:
With the engine off, open the hood and pull out the trans dipstick.
Examine the fluid on the end of the stick.
Is it black, brown or pink?
If it is black or brown, does it smell "burnt"?
If the fluid is not clear pink, and smells burnt, go to a place that does transmision flushes. You just may need a good ATF flush. DOn't drain the pan and refill it, ther will still be 3 quarts of dirty fluid in the trans. Get it flushed, you will probably be OK.
Thanks for choosing FixYa for assistance!
Feb 24, 2009 | 1994 Toyota Camry
Pininfarina finacial trouble
yap they facing serious financial trouble. The company has lost 39.1 million euros in the first nine months of this year, an increase of 22.8 million euros over the same period in 2006.but in an article i read that it wouldn't effect there selling because this model is really established
May 14, 2008 | 2005 Fiat Pininfarina
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
