Braemar heater fault code
Error code -13 what does that mean?
  • 499 Answers
Heater starts then stops. Screen shows reset and fault 13
You need to look on the legend on your furnace blower door for the meaning of this error code, it can only be a few things, since you say the unit lights up and runs but shuts down the high limit circuit is suspect, I would check the air filter and insure all supply vents are open, the limit may be bad however a cracked heat exchanger will also do this so a free inspection by your gas co will be a great idea once you get it running again.
Apr 06, 2015 | Heating & Cooling
What does error code 13 mean?
1) Copy following links for Rheem tankless error codes
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-Error-code-13.pdf
2) Maintain water heater as shown in product manual to avoid common error codes.
Dec 28, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
C4 13
Could be bad thermocouple, or oxygen sensor, not enough fresh air to unit.
Probably bad PC board. Rheem will send new board and you can install yourself.
Bad PC board is kind of like the motherboard on your computer, so expect same level of performance after replacing motherboard ... which usually means the computer's days are numbered before another major problem.
Copy following links:
http://waterheatertimer.org/pdf/Fault-codes-11003.pdf
http://waterheatertimer.org/pdf/Error-code-13.pdf
Sep 20, 2012 | Water Heaters
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
I have an Rinnai Avenger 25TR heater. The problem is that the heater ignites, it starts, but then it turns off. A red light then flashes and the number 13 also flashes in the bottom right hand corner of...
Paul, the Error Code Fault 13, indicates a Combustion Control Fault. This could mean, not enough gas for safe combustion or to much gas for continued operation. In any event, if requires a service call from an authorized Rinnai Service Technician to solve.
Just in case you have misplaced your Owner's Manual, I have included a link to it, that you can download and print for future reference.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/CI_Avenger_Blaze_Dynamo_Enduro.pdf
Hope this helped you.
Jul 18, 2011 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
Rinnai Avenger 25 error 13!
thermocouple high cut out on convection fan rinnai fitters job , have to wait sorry , it is in the manual under fault codes .
Jul 06, 2010 | Heating & Cooling
I'm getting an "E 13" code on my Monitor 2400; what does that mean? I don't have a manual to tell me.
E 13 means ignition failure. You can see a list of error codes at www.monitorproducts.com. What happens when you try to light the heater? You can contact me at nitensheaterservice@embarqmail.com.
Jan 06, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Paloma tankless ptg42 water heater error code c4/13
4 error message, the 4th (last) error code is #13, not enough oxygen.
Check the location of the heater, if it is fine the ODS sensor (actually is a thermal couple) is bad.
Dec 25, 2009 | Rheem Paloma Tankless Water Heaters...
Heating & Cooling Logo
620 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
